body lift dimesions needed!
  • 2779 Views
Offline Chief
  • 678
  • Whaddya lookin at??
« on: October 12, 2004, 09:22:06 AM »
I need the dimensions of a body puck for a Tracker. Having a body lift built. Much cheaper then buying after market!
So I need to know how wide the body pucks are, and how big the whole in the middle needs to be. Thanks!
Re: body lift dimesions needed!
« Reply #1 on: October 12, 2004, 10:11:44 AM »
I built 4" with 2" heavy wall tubing
the hole, not whole, needs to be about 7/16
to 1/2, that should be fine
Good Luck
Offline Chief
  • 678
« Reply #2 on: October 12, 2004, 11:01:50 AM »
ok, so I need a 2" diameter body puck, with a 1/2" runing through it for the bolt, correct?
And how many will I need? 6 or 8? Ya figure as many times as I have been under that damn thing, I'd have counted em!!  ::)
« Reply #3 on: October 12, 2004, 01:17:58 PM »
Well it's not just that easy, you see, the body
has studs, and you cant just put in longer bolts.
You will have to either get some hollow bolts
that fit the studs, or an open spacer that will
let you put a nut on the stud, and another bolt
thru the frame
And you need 8 spacers, the front is the only
one that you can just put a long metric bolt into
Offline Chief
  • 678
« Reply #4 on: October 12, 2004, 02:14:50 PM »
hmmmmm gonna have to do some more research on this I guess. Any good websites with some pics of an install? Thanks for the help!
« Reply #5 on: October 12, 2004, 05:19:39 PM »
Heres the link to Heathers budget bodylift.
should answer must of your questions.
http://www.granitepath.com/friends/kd7hcg/pictures/bodylift2/bodylift2.htm
I guess this one shows pics but it does have some good info.
« Last Edit: October 12, 2004, 05:21:34 PM by trickker »
Offline Chief
  • 678
« Reply #6 on: October 12, 2004, 09:48:42 PM »
Thanks man. i found that same articlae about an hour after I posted this thread! Good info!
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #7 on: October 13, 2004, 02:33:36 AM »
Here's a link to the actual article:
http://www.zuwharrie.com/content/view/11/27/
Heather
Heather Galvin
Offline Chief
  • 678
« Reply #8 on: October 13, 2004, 10:18:54 AM »
Heather
That;s the one I read! Good dtuff. I just need to find some 2"x3" box tubing now! I only want/need 2". :D Thanks for the write up!!
