timeing problem
  • 1737 Views
Offline Eden1
  • 73
timeing problem
« on: May 13, 2008, 06:11:01 PM »
i replaced my distributor shaft today and now it dosnt run?????1.went to tdc-2.i marked the cap where #1 is-3.pointed the rotor towards the mark i made earlier on for #1 wire.I even went as far as checking the timing belt notches under the timeing cover??????   what did i miss?????im lost
Offline derekj
  • 784
  • i'm the canadian guy eh?
Re: timeing problem
« Reply #1 on: May 13, 2008, 06:20:40 PM »
Did you put the gear on the shaft 180 deg out? Usually the gear only goes on one way because of the cuts in the gears are not even numbered.
Derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
Offline Eden1
  • 73
Re: timeing problem
« Reply #2 on: May 13, 2008, 06:31:11 PM »
Is that because there is a notch on the shaft?is there a mark somewhere on the shaft or anywhere else im missing?does the rotor only go on one way?
Offline Eden1
  • 73
Re: timeing problem
« Reply #3 on: May 13, 2008, 08:55:35 PM »
ok i checked if there was power coming out of the coil with the key on and there wasnt.does this mean anything guys?
Re: timeing problem
« Reply #4 on: May 14, 2008, 04:58:18 AM »
Probably not if its EFI. Have you checked for a spark at the plugs?
