Diamater of fuel hose
  • 1670 Views
Offline 92Sidekick4x4
  • 1456
« on: October 12, 2004, 06:07:11 PM »
I am needing an approximate diameter of what the inner diamater of the fuel filelr hose so i can put a steel spacer in mine.
Re: Diamater of fuel hose
« Reply #1 on: October 12, 2004, 08:02:56 PM »
It is best to get a section of
Marine Exhaust Hose, That's
what I'm using, if you don't cut
your stock hose at just the right
place, it won't fit right, even with
a steel sleeve spacer
I have a source if you want it,
International Rubber Supply
Colton, Ca.
  • 1456
« Reply #2 on: October 13, 2004, 03:23:46 AM »
heather where did u cut yours?
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #3 on: October 13, 2004, 03:35:51 AM »
Right in the middle. I think the steel spacer was basically galvinized pipe that I found in the back yard. I believe it was 2"?
Here's some photos:
Heather Galvin
