tranny crossmember
  • 2028 Views
Offline tipover
  • 422
tranny crossmember
« on: May 15, 2008, 12:30:33 AM »
i've searched...
Is it just me or is the tranny/Tcase crossmember on a kick a piece of junk,  it is constanly snagging things and is always getting bent up.  does anyone make a bulletproof one?  Or am i going to be the first person to make one?
RV Dingy-2003 2 door tracker
RV- 31' Monaco Mckenzie
Re: tranny crossmember
« Reply #1 on: May 15, 2008, 04:43:24 AM »
No its not just you, without a skid plate it won't last very long. If you do make a heavy duty one then you'll need to reinforce or replace the mounts on the frame or you'll just bend them instead.
Offline Trackin_Tracker33
  • 137
  • Have Gun will travel
« Reply #2 on: May 15, 2008, 06:22:20 PM »
Im in the same boat.... My crossmember is trashed and I cant find a replacement anywhere.  I can find plenty of 95 and below    but never    96 and up.   Once I find a new crossmember then im making a skid plate for sure.
I got your Jeep thang,  thats why it burns when I pee..
Mods: BDS 2" susp., Rocky Road +2'' Body, OME struts, flipped strut mount, custom High lift mount, CB, 30x9.50x15 RVT's
Comming soon.... To hell with IFS,  SAS'N it
Offline tipover
  • 422
« Reply #3 on: May 20, 2008, 12:14:11 PM »
so the easy solution is the skid plate uh... so there really isn't a need for a better crossmember.
« Reply #4 on: May 20, 2008, 02:23:21 PM »
It works for me  ;D. It prevents the edge of the crossmember getting caught up and being pushed back (or forwards) which is the main cause of damage. It also spreads the force of any impact but I suspect that if you dropped it hard onto a big rock you could still bend the crossmember up a bit.
  • 137
« Reply #5 on: May 20, 2008, 05:17:57 PM »
I said to hell with buying a new crossmember..... just fab up you own
  • 137
« Reply #6 on: May 20, 2008, 05:44:54 PM »
Check out mine on this forum... GO Tracker's cross member
