manual hub!!!
  • 2113 Views
Offline MaD.72
  • 183
  • It's not what you buy, it's what you built!!!
manual hub!!!
« on: May 15, 2008, 06:41:06 AM »
Does anyone know where i can find some manual hub for a 2002 Tracker??
Thank's
Offline biker
  • 730
  • It's a sickness I tell ya
Re: manual hub!!!
« Reply #1 on: May 15, 2008, 07:09:39 AM »
Look in the wreckers for an 89 to 98 that has them. Make sure you grab the bolts and cone washers and they will bolt right on.
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline ROSS
  • 1412
Re: manual hub!!!
« Reply #2 on: May 15, 2008, 07:29:22 AM »
call HAWK 1888-SAMURAI
Offline RJkick
  • 634
Re: manual hub!!!
« Reply #3 on: May 15, 2008, 11:42:51 AM »
You can always ask around
I have a set but there are only 10 of th e12 bolt\cone washers so you would need to find 2 more
$40 shipped
Offline MaD.72
  • 183
Re: manual hub!!!
« Reply #4 on: May 17, 2008, 08:18:43 AM »
So you're telling me that the old tracker manual hub will fit on a 2002 tracker with automatic hub???
Re: manual hub!!!
« Reply #5 on: May 17, 2008, 08:48:09 AM »
I believe that the 2002 Tracker has an air operated diff. The hubs are just a splined cap that can be replaced by the FWHs from the early models.
Offline MaD.72
  • 183
Re: manual hub!!!
« Reply #6 on: May 17, 2008, 09:28:04 AM »
Thank's Rhino..
