Strut tower brace design info needed.
  • 2513 Views
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« on: May 15, 2008, 09:14:36 AM »
I have bent my strut towers, so a tower brace is a necessity.  Above the engine will be tight but I am running a 2" body lift.
I've got a few ideias in mind:
1. Cut off tower shrouding
2. Form a front and rear reinforcment brace to run from the frame along the strut tower and above.  Use this same braceing to incorperate the mounting for the tower to tower brace.
3. Weld it to the towers, dial in the correct camber, reinforce it /weld / brace it to the frame.
What other ideias are out their.  I've surfed Ebay a while but I do no find any adjustable braces.  I've gotta jack my towers back out and I'd prefer to keep the bar adjustable.
Re: Strut tower brace design info needed.
« Reply #1 on: May 15, 2008, 10:34:39 AM »
Maybe use the strut brace and mounts of a GV and modify if from there?
Offline whitfield
  • 633
  • 4-dr Kick on 34's
« Reply #2 on: May 15, 2008, 10:55:29 AM »
I had a 97 Sidekick sport brace a few years back and let it get scrapped.   Definatly not a bolt on, but probally a good starting point.   (Kicking my own arse)  :'(
Offline kingzoo
  • 461
  • I LOVE MY JLX SIDEKICK
« Reply #3 on: May 15, 2008, 11:09:43 AM »
  Trying to use a stock brace sounds like a solid start.If not,you mihjt try to check out some aftermarket adjustable braces for ideas.It shoild not be too difficult except for the possible space constraints.
KING ZOO!!
« Reply #4 on: May 15, 2008, 01:38:51 PM »
The old Explorer Pro-Comp 2.5" lift kits had braces...Maybe call Hawk and see if he has a parts kick on the yard with that lift on it  :-\
Offline cj
  • 1276
  • I drive a really big ATV
« Reply #5 on: May 15, 2008, 01:40:02 PM »
I'd start with a brace from a Sport. You'll need to cut away some of the tower now due to the bodylift and you'll need to cut a section out of the middle as the Sports are wider but that is where you can then create an adjuster.
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #6 on: May 19, 2008, 08:39:22 AM »
Here's one picture I found in the arcives.  This is the very first build of the rockstar.
32 MTR's Warn 8000i
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
« Reply #7 on: May 20, 2008, 12:43:59 PM »
I built my own from tower to tower across the motor. I think that welding tube from the frame to the tower wont help them from caveing inwards just my .02
   Kevin
  PS use at least .120 wall 1.5" tubing I bent my first one that was thinner wall
Offline kingzoo
  • 461
« Reply #8 on: May 20, 2008, 08:11:48 PM »
   I agree.Running the brace from side to side is really the best way to go.
KING ZOO!!
