Nitrogen in your tires?
  • 15 Replies
  • 4020 Views
Offline 99Trackerconv
  • 430
  • I love my Tracker
« on: October 08, 2004, 10:32:21 PM »
I've been hearing a radio commercial for somewhere near me, that they will fill your tires with nitrogen with free refills.
What is the pro's and con's of inflating your tires with nitrogen?
12 Chevy Sonic hatch.  1.4t 6spd.... DD
01 4dr Zr2 project... coming soon :)
Offline Agent Orange
  • 711
    • Trying to learn
Re: Nitrogen in your tires?
« Reply #1 on: October 09, 2004, 12:23:35 AM »
for 4x4's and passenger cars nitrogen filled tires are of no use. for race car tires nitrogen maintains tire pressure, by not expanding when heated. regular compressed air is all you need.
nitrogen is chemicaly inert, and displaces oxygen.
carbon dioxide will change tires pressure during temerature changes, also when co2 is mixed with moisture it forms carbolic acid. if someone were to only use co2 in there tires over a period of time carbolic acids would form, and deteriate the rubber of the tires, and steel rims would rust on the inside. for in the field quick tire fills, and to operate power tools co2 works great, but you should replace co2 filled tires with compressed air afterwards.
Offline 1bigtracker
  • 3409
« Reply #2 on: October 09, 2004, 02:17:23 AM »
learn somthin new everyday,  thanks!
stu
Offline Iron_Crow
« Reply #3 on: October 09, 2004, 02:44:57 AM »
Just to clarify: All gas expands when heated.  Nitrogen is a gas.  It is more chemically inert than oxygen, as pointed out, and is DRIER.  No moisture in it due to the manufacturing process that separates the nitrogen from oxygen that makes up air.  It is the lack of moisture that results in the pressure stability under differing temperature that racers like.
Iron Crow  -  An X-90 with freakishly large wheels, bent on world domination!  90:1 crawl ratio and ARB front & rear
  • 430
  • I love my Tracker
« Reply #4 on: October 09, 2004, 03:19:28 AM »
OK, cool   :o :-/
Thanks for the info!
  • 711
    • Trying to learn
« Reply #5 on: October 09, 2004, 04:35:31 AM »
yes the best property of nitrogen is it's ability to displace moisture. i forgot to add that as i posted that after waking up on the couch at five in the morning :) man my neck is sore, dam couch. that's why binoculars, and scopes are nitrogen filled, they don't fog up in differing temperatures.
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
« Reply #6 on: October 09, 2004, 05:30:39 AM »
Cool I didn't know that, makes excellent sense.
Dude don't you have a bed?  ???
Offline zukiboy
  • 42
  • Wheel Forever !!!
« Reply #7 on: October 09, 2004, 04:17:03 PM »
When I road raced motorcycle's we put nitrogen in the tires for the reason Agent Orange said. But wouldn't be of much use in a 4x4.
88 sami
3"lift 30's
No matter where you are there you'll be
« Reply #8 on: October 09, 2004, 09:13:11 PM »
I watched a documentary about a group
of 4x4s that went to Greenland, and they
filled their tires with Nitrogen to keep the
pressures stable, even at sub zero temps
And it can't hurt anyway. Compressed air
has moisture in it, and can cause rust inside
the wheels too.
« Reply #9 on: October 10, 2004, 11:39:33 AM »
I was at COSTCO today and saw this.
« Last Edit: October 10, 2004, 11:41:35 AM by trickker »
  • 430
  • I love my Tracker
« Reply #10 on: October 10, 2004, 02:38:22 PM »
So does this meen your gonna try it HOTROD?
« Reply #11 on: October 10, 2004, 05:36:36 PM »
Ya, gotta rotate the air in my tires anyways ;)
« Reply #12 on: October 10, 2004, 05:40:03 PM »
On Second thought. Airing up and down my tires everytime I go wheeling I would think it would get spendy pretty quick. ;D
Maybe Helium.
It'll Make the Tracker float over the rocks  ;)
« Last Edit: October 10, 2004, 05:40:25 PM by trickker »
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #13 on: October 11, 2004, 05:17:29 PM »
Once or twice a year I have to have my tires removed to get the water and mud out of them. Running them at 4-6 psi through the mud is good for that.  I don't think Nitrogen would help me out.   (Never totally blown a beed though)
Glad Discount does that for free when you buy their tires.  ;D  Matter of fact I need to get them done now before winter hits.
« Last Edit: October 11, 2004, 05:18:21 PM by lil_Truck »
32 MTR's Warn 8000i
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #14 on: October 11, 2004, 05:19:53 PM »
I worked with a guy that had his snow tires filled with cloride on his S-10(2wd)
Swore it was the best snow vehicle he has had????
Don't know if I beleave him though?
32 MTR's Warn 8000i
