performance 1.0L????
  • 2143 Views
Offline bandit86
  • 1641
  • elv8rguy
« on: June 01, 2008, 09:57:03 AM »
has anyone ever heard of a done up 1.0L sj engine?  with a whopping 45 hp and no torque I thought maybe a bit of a buildup with readily available parts might be what my lj needs.  maybe a turbo blowing through the carb as a last resort
actually, I dont even know what the compression ratio is, but probably low enough for a turbo.
Re: performance 1.0L????
« Reply #1 on: June 01, 2008, 01:14:14 PM »
The most popular upgrade over here is a 38mm SU carb and a header - a good power gain can be had from just those modifications. The 413 ignition is used for reliability. There is also a company in Europe that sells a manifold for twin Webers. The engine was used in the Whizzkid and there is a site with some info on tuning. Before the 413 was launched there were a couple of companies marketing turbo conversions. PM me if you want a scan of a magazine article.
Cheers
James
http://www.suzuki-sc100.demon.co.uk
http://www.chadil.be
« Last Edit: June 01, 2008, 01:34:29 PM by Rhinoman »
Offline JoeCool
  • 164
  • Carpe Noctum!
    • cardomain
« Reply #2 on: June 01, 2008, 04:02:59 PM »
You'll want to talk to these guys. http://www.teamswift.net/  NMc
5psi turbo '90 2dr 5spd 8v Tracker, Lt235s, 1" spacers, Rocker Rails, Warn Hubs, Custom half door,--GONE!
New, Sammi Tintop
« Reply #3 on: June 03, 2008, 05:00:33 AM »
The 1ltr Swift engine is a 3cyl, the 410 engine is a 4cyl.
« Reply #4 on: June 03, 2008, 01:36:25 PM »
There was two different model of Turbo Chargers available for the SJ-410 in the UK, I haven't heard of anything after market though.  Putting a turbo on a carbed setup is always tricky.
