thorley header on 1.6 problem
  • 1901 Views
Offline brawnyrebel
  • 131
  • i've cought a case of samuraitis
« on: June 03, 2008, 05:07:36 AM »
 I recently moved my thorley header from an 8v 1.3 to a 1.6 8v. There is a little pipe on the tube closest to the fire wall that sends exhaust back into the engine for some reason. The little pipe dos not line up exactly with the hole in the 1.6 block and creates a little leak.  Has anyone ever experienced this and what did you do?  I am running a stock tracker gasket if it matters
If its not broken, break it
Offline lostsamurai
  • 433
  • LOSTSAMURAI
Re: thorley header on 1.6 problem
« Reply #1 on: June 03, 2008, 05:53:53 AM »
im not sure that can be done i know they are sold completly sepratly i bought the thorely for one of my 1.6 16 valves and the calmini for my other ( i like the calmini more ) but on both there was a diffrent item than the 8 valve and a lot more money too
« Reply #2 on: June 03, 2008, 07:43:41 AM »
I have a 92 sidekick with the 1.6l 8v and the doug thorley header.  Guess what?  No tube.  I just double checked and mine is completely solid over where your little pipe is.  Mine runs great so you don't need that tube (for reference my header was bought from RRO this winter).  I saw the pics on trailtough that show your little tube and I am not sure why you have a different one.  I would probably just order a new gasket for the version without the tube and put that in.
« Reply #3 on: June 03, 2008, 01:41:52 PM »
That tube is part of the EGR system (see the other thread)
http://www.zukiworld.com/forum/index.php?topic=21789.0
Offline brawnyrebel
  • 131
« Reply #4 on: June 03, 2008, 01:58:17 PM »
 I suppose i could just plug the egr hole oon the block and header and run it that way. I may shoot thorley an email tonight
