Samurai suspension kits
  • 2338 Views
« on: June 03, 2008, 01:27:48 PM »
I am an Samurai owner from Romania and I want to know from your experience which upgrade suspension kit is more durable. I want to buy Calmini but I want to be sure that is the right choice or I can build my own lift kit based on the other 4x4 cars.
The bigest problem is the shiping to Romania but I'll manage some how because my father lives in California.
Offline lostsamurai
  • 433
  • LOSTSAMURAI
Re: Samurai suspension kits
« Reply #1 on: June 03, 2008, 06:04:24 PM »
what are you working with? stock setup can easily be sprung over giving you roughly 5" lift and it costs nothing but time and knowledge.
Offline picklepants
  • 42
« Reply #2 on: June 03, 2008, 09:48:28 PM »
thatll let you run 32"s easy
Offline truckasaurus44
  • 265
  • I'm a new world Samurai & a Redneck nonetheless!
« Reply #3 on: June 04, 2008, 08:18:13 AM »
SPOA fits 32's easy?  Maybe with some body hacking or a body lift, but my 4.5" spoa only fit 31's and even then, I had to do some trimming and move the axle forward 1".
Offline lostsamurai
  • 433
  • LOSTSAMURAI
« Reply #4 on: June 04, 2008, 11:49:45 AM »
i ran 35"s with an spoa and revolver shackles ::)
« Reply #5 on: June 04, 2008, 05:13:52 PM »
It really depends on what condition your springs are in.  Mine springs sit level and I was able to run 33" tires with pounding in the rear of the fender well for clearance.  However one of the Samurais I run with had a negative arch to his springs, gave him just enough room to clear the 31" tires.  A helper spring added to the leaf pack can easily turn a standard SPOA lift up to 6" or so.
