putting in my sifters
  • 16 Replies
  • 4670 Views
Offline 92Sidekick4x4
  • 1456
« on: October 05, 2004, 03:26:54 PM »
Hey
i got my shifters extedned today i am having problems puttign the shifter back into the tranny thing any sugestions?
95xl7
Re: putting in my sifters
« Reply #1 on: October 05, 2004, 04:04:09 PM »
Have you been drinking too?  ;D
  • 1456
« Reply #2 on: October 05, 2004, 04:15:01 PM »
what do u mean,
i mean that i cant get the whole shifter down into the thing it goes into lol its hard to explain, any one?
  • 1456
« Reply #3 on: October 05, 2004, 05:26:10 PM »
c'mon i need help
Offline explosivo
  • 3157
« Reply #4 on: October 05, 2004, 05:41:14 PM »
Make sure that the plastic cylinder thinger is pointing up and down so the trans shifter can slide in correctly, then you just have to push down the springy-locking collar thingy down and onto the tabs and put the rubber cover back on ;)
omghi2.us[/url]
  • 1456
« Reply #5 on: October 05, 2004, 05:45:34 PM »
whats the plastic thingy u r talkin about?
« Reply #6 on: October 05, 2004, 06:16:28 PM »
The shifter has a thin section at the bottom,
thin faces sides, you didn't forget to have the
spring and the metal bayonet cup on the shaft
before the extension was welded on did you ???
The bayonet cup pushes down and turns clockwise
to lock, wear gloves if you can, as this has semi
sharp edges and could cut/slice your fingertips
That should help I hope
  • 1456
« Reply #7 on: October 05, 2004, 06:53:21 PM »
ya its on there now i am able to push the cup down but its hard to get it locked in i guess i gotta keep trying.
« Reply #8 on: October 05, 2004, 07:14:19 PM »
Ya turn hard, that's why I said gloves,
it felt like I was going to have cut finger
tips when I finished mine.
Also I have an Automatic Trans, so I
only did the T-case, as the auto has
a cable and needs no extension on it
Offline mbmarkyb
  • 461
    • UK Vitara
« Reply #9 on: October 05, 2004, 07:36:43 PM »
two screw drivers seemed to do it for me, apply pressure down and turn at the same time , my t case one is tight the gear stick one goes in easy :-)
Markyb (UK)
UK Vitara JLX SE
Offline SiKiD_01
  • 574
  • Fully Sik, Flying Vit.
« Reply #10 on: October 05, 2004, 09:45:15 PM »
yep, its one of those push in, and turn kinda locking things.
i had a mate push down, and i had a couple of flat head screw drivers to turn it and lock it in.
same with transfer.
« Reply #11 on: October 06, 2004, 03:25:04 AM »
That kind of attachment is called
a Bayonet mount, kind of like your
Light Bulbs  Mate    ;)
Good to hear you got them back in
So .......  How does it work ???
« Reply #12 on: October 06, 2004, 04:24:46 AM »
I couldn't get mine to turn either. The bayonets are just some fancy bolts that screw in from the front and back of the turret. I backed mine out, pushed the cup down (lined up with the holes) and tightened up the bolts again. I did notice the bolts were Loctited but they haven't fallen out yet, 18,000 miles later ;D ;D
« Last Edit: October 06, 2004, 04:25:10 AM by Rhinoman »
  • 1456
« Reply #13 on: October 06, 2004, 11:28:42 AM »
im heqadin out to finish up in a few mins that is what i will do
  • 1456
« Reply #14 on: October 06, 2004, 12:26:32 PM »
this dam thing is still not going in and im gettign pissed off, i tried to undo the screws then push down th ecuppling but i cant get it lined up with the hoiles  to put the bolts in >:(
