Weber Carb
  • 11 Replies
  • 4212 Views
Offline SkipTLoo
  • 26
Weber Carb
« on: June 17, 2008, 08:55:07 PM »
Just bought a new WEBER carb and put it in and took it out this weekend and had some fun in my 86' zuk.  runs great until i go up hills........start up hill and as soon as I hit the bottom of hill in 2nd low I start bogging and seems like it is starving for some fuel....so i adjusted the float and it works a little better and messed around with Distributer Cap, and timing.  And all in all its better but still bog's out when I get to the top.  Should this weber do this???  My stock ran better that this!!!!!
Re: Weber Carb
« Reply #1 on: June 17, 2008, 09:00:53 PM »
oh this is no surprise my friend, weber cards are notorious for uphill bogging, switch to fuel injection, youll never go back!
Offline SkipTLoo
  • 26
Re: Weber Carb
« Reply #2 on: June 17, 2008, 09:16:41 PM »
so there is nothing i can do??
Offline SkipTLoo
  • 26
Re: Weber Carb
« Reply #3 on: June 17, 2008, 09:17:02 PM »
besides EFI
Re: Weber Carb
« Reply #4 on: June 17, 2008, 09:18:00 PM »
as far as i know there isnt, webers are great for power increases, but on the trails then tend to have trouble on steep hills, which can become very annoying...
Offline SkipTLoo
  • 26
Re: Weber Carb
« Reply #5 on: June 17, 2008, 09:38:35 PM »
im soo upset >:( is there a carb out there that will work?? how much would it cost to switch to EFI??
Offline Amilla
  • 1076
Re: Weber Carb
« Reply #6 on: June 17, 2008, 09:47:51 PM »
There is another style of carb you can switch.
Take a look at side draft carbs, no up hill bogging.
Heres one of the sites that sells side draft carbs
http://www.zuksoffroad.net/samurai_engine.htm
And heres petroworks kit
http://www.petroworks.com/drivetrain-carberators.php
just scroll on down through the pages till you find them.
If it turns out you don't feel like buying a new carb, you could flip your carb 180* so that it wont flood out going up hills.....just going down.
Hope this helps
Amilla
Offline SkipTLoo
  • 26
Re: Weber Carb
« Reply #7 on: June 17, 2008, 09:57:23 PM »
it will still bolt on right???? ???????
Offline rascott
  • 669
  • 15
Re: Weber Carb
« Reply #8 on: June 18, 2008, 03:42:02 AM »
skiptloo
i experienced the same symptoms on climbing. i think fuel was spilling into the air correction jets.
i remounted the carb. "backwards" w/ float bowl to the firewall and limited the float drop.
this seems to have cured the problem on climb.
i thought i would still have the problem on down hill, but i haven't.
richard
  • 6603
  • 69
Re: Weber Carb
« Reply #9 on: June 18, 2008, 11:33:10 AM »
A couple of things that may help. First, why did you mess with the timing? If it was correct with your stock carb, it isn't magically going to move. Set it at factory specs and leave it alone for now. Second, what do you mean by bogging? I think most of the responses here assume that you mean that the engine is flooding out and coughing sputtering black smoke. BUT you may mean that there is a loss of power? Which is it?
General info: The newer Weber design has the float bowl vented to the charcoal cannister so the old floodin' out problem is gone. If you have an older design it is possible to convert to an "offroad" version.
Waiting to help, Eric
Offline SkipTLoo
  • 26
Re: Weber Carb
« Reply #10 on: June 18, 2008, 01:47:47 PM »
Its smoking and sputtering???.....adjusted lean screw and float and idle but nothing seems to work??? think it might be fuel filter?
  • 6603
  • 69
Re: Weber Carb
« Reply #11 on: June 18, 2008, 02:10:29 PM »
Well your other post with the dying and then restart sounds a lot like a fuel filter OR float bowl adjusted too low.  On your Weber, I'd recommend getting one of those $15 fuel regulators at a parts store and regulate your fuel pressure to 1.5 lbs. Reset your float bowl to it's correct location. Also set your timing back to stock. Now, go out and try it. Only change one thing at a time as you adjust.
Below is a pic with instructions on float levels. Also, for the adventurous, a performance upgrade... Try at your own risk.
Hope that helps, Eric
