have you try the ANTI SWAY bars?
  • 2591 Views
Offline lokomonkey
  • 41
« on: October 05, 2004, 06:30:46 AM »
I need to know "whats the point on having an 'anti sway' bar install, the one from Calmini. does it really affects your driving? how?
Offline lokomonkey
  • 41
Re: have you try the ANTI SWAY bars?
« Reply #1 on: October 05, 2004, 06:32:13 AM »
sorry I forgot!! install in a '90 sidekick
Offline wolf66
  • 193
« Reply #2 on: October 05, 2004, 06:35:43 AM »
You will get less lean in high speed cornering on road, but less flex off road.
'96 Suzuki X90-4" lift-snorkle-30x9.5's on 8x15 wheels-5.12 gears-winch-added rear seat-DT header-PioneerMP3-CB-GPS-roof rack-rear mounted full size spare
Offline Cwkick
  • 888
« Reply #3 on: October 05, 2004, 06:52:55 AM »
I had a set and they made my Tracker very stable and would corner very flat, but it killed my flex off road.  If you mostly drive on the street or have a lifted Trak/Kick that leans a lot in corners I would recommend them.  Otherwise, spend your money on something else.
Cwkick
Offline cocobeachtracker
  • 43
  • 2006 Grand Vitara Luxury
« Reply #4 on: October 06, 2004, 01:42:51 AM »
I built a remote swaybar disconnect in my tracker and I can definitely tell the difference on the road. I like the results but not the operation.  I am redesigning the disconnect and will post when I get one that works better.
2006 Grand Vitara Luxury, Trailer hitch, dynamat
« Reply #5 on: October 06, 2004, 02:23:01 AM »
I think most of us will be interested in seeing how that turns out.
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #6 on: October 06, 2004, 05:26:20 AM »
Speaking of...
anybody seen any place other than calmini or p.s.t that has performance sway bars for a sammy?
we used a sammy sway bar for the kick when we did this SAS setup, and it'd be cool if I could get one that's high performance, with poly bushings, to help me out on the road.
Heather Galvin
Offline Agent Orange
  • 711
    • Trying to learn
« Reply #7 on: October 06, 2004, 11:54:15 AM »
Speaking of...
check out calmini's sway bars for the sami
Offline jagular7
  • 1026
  • Jagular7
« Reply #8 on: October 06, 2004, 12:23:03 PM »
Speaking of...
Why not look for the Currie Rock bar? It's just a simple torsion bar contected with long swing arms which are then attached to the axle. Lifted coiled Jeeps run these continuously, even off-road. Some of the rock crawlers run them during competition.
Lenexa, KS
