aisin hub gaskets
  • 2668 Views
xoloski
aisin hub gaskets
« on: June 21, 2008, 05:48:10 AM »
I'm rebuilding my front end and need a set of aisin hub gaskets, and wheel bearings,
where should I look for these? Suzuki dealer? aftermarket?
where would you buy these?
Thanks,
Re: aisin hub gaskets
« Reply #1 on: June 21, 2008, 07:53:48 AM »
I would give Hawk Suzuki (http://www.hawksuzukiparts.com) a call.  As for the hub, if anything I just throw a little silicone sealer on them and call it good.
Your local auto parts store could probably get them for you next day as well.
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
« Reply #2 on: June 21, 2008, 10:11:35 AM »
You can make a set of gaskets for your Asin hubs with gasket material.  Most parts stores sell it by the sheet - which will make more than the two that you need!
Set the face of the hub on the sheet and gently tap the top of the hub casting with a deagblow hammer or rubber mallet to impress the face of the hub into the gasket material.  Use an exacto-knife to cut the gasket along the impression.
Cheap and you don't have to wait for the guy in the brown truck... Plus, it's not as messy or "hit-and-miss" as silicone sealant.
I hope that this helps!
Ack
Offline Amilla
  • 1076
« Reply #3 on: June 21, 2008, 10:28:41 AM »
Go with anything BUT a suzkui dealer!!!
There prices are a weeee bit high.
Amilla
xoloski
« Reply #4 on: June 24, 2008, 03:46:06 PM »
I ordered a set of four, enough to do the entire vehicle, today from Jim at Petro Works.
Had a great conversation about parts from the Suzuki mother company.
The gaskets were about $5 each, which is feel if well worth not having to use or remove RTV.
