Milemarker Locking Hubs? Any good?
  • 3625 Views
« on: June 23, 2008, 08:38:21 PM »
Anyone know anything about Milemarker hubs from autozone?  I need to replace mine and these are cheap... anyone know about them?  Or should I spend the extra$ and get Warns from lowrange?
Re: Milemarker Locking Hubs? Any good?
« Reply #1 on: June 24, 2008, 02:54:11 AM »
Ever consider just getting used ones?
If you go with big tires, I believe there's lockers with mechanical fuses in them. Tney're designed to "break" before other more critical components do, and the fuses are small & cheaper than a new axle / diff / t-case
« Reply #2 on: June 24, 2008, 05:38:13 AM »
I would love to go with used ones... do you have any good sources?
« Reply #3 on: June 24, 2008, 07:53:51 AM »
Stock hubs are stronger than aftermarket hubs......from what I have heard.
Offline Amilla
  • 1076
« Reply #4 on: June 24, 2008, 09:54:38 AM »
I have 2 sets of stock samurai asain hub's.
2 of them are fresh off my sami.
The other 2 are not a fresh looking, they were just my back up pair.  They just need to be cleaned up and lubed up.
Amilla
« Reply #5 on: June 24, 2008, 05:50:57 PM »
will those work on a 95 sidekick?
« Reply #6 on: June 24, 2008, 06:59:24 PM »
With a couple of gaskets the Sammy hubs should work on a Sidekick.  I would also try giving Hawk Suzuki a call.  They usually have a pretty good selection of used parts.
Offline Amilla
  • 1076
« Reply #7 on: June 25, 2008, 11:42:44 AM »
You would need a gasket and some cone washers i believe.
Amilla
« Reply #8 on: June 26, 2008, 09:28:54 PM »
well i got the hub off and the spring was totally jacked up.  i guess this is why it would not engage.  I tried to fit it back together but it looks like it is fried. I also wish you could buy the springs after market... oh well. used hubs here i come....
