Noob needs advice on setup.(what a suprise)
  • 1758 Views
Offline TopHeavy96
  • 488
« on: July 06, 2008, 09:22:15 PM »
I have a 96 tracker 4 door, planning on getting the calmini 6 inch combo.  I could use some advice on tire size.  So far its looking like BFG Mt's  235-85/16 measuring 32x9.3 Anyone think I can go bigger with the calmini setup? I don't mind cutting fenders but I don't want any frame rubbing if possible.  Thanks.
Offline lostsamurai
  • 433
  • LOSTSAMURAI
Re: Noob needs advice on setup.(what a suprise)
« Reply #1 on: July 06, 2008, 10:45:53 PM »
i run 33,s but i need to trim the fenders ::)
Offline jeff1997
  • 1228
  • 27
« Reply #2 on: July 07, 2008, 01:23:16 PM »
I run 31/11.5/16 Super Swamper LTB's with a 2" coil anf 3" body lift. The fenders are trimmed a little. The tires are a lot cheaper than BFG's
3" Masterkit1 body lift
Custom strut spacers
Offline bzzr2
  • 1011
« Reply #3 on: July 08, 2008, 07:09:59 AM »
tires will rub the frame unless you have the correct backspacing on your rims, then again if you don't already have 16inch rims you could fit some 32.9.5 tsl swampers on there with the stock rims and wheel spacers to avoid frame rub....
09 taco reg cab short box 4x4
