? about torque converter lock up
  • 10 Replies
  • 3176 Views
Offline gm5226
  • 8
« on: July 09, 2008, 05:42:11 PM »
is there a way to disable the tcc lock up circuit,where the trans will operate as a regular 3 spd. auto w/o the lock up feature?    ???
Re: ? about torque converter lock up
« Reply #1 on: July 09, 2008, 05:50:34 PM »
For what purpose??? It's only supposed to work in 3rd to
increase MPGs. Are you having early lockup issues? like in
1st or 2nd gear? and in answer, yes a switch in the right circuit
would work to control lock up.
Offline gm5226
  • 8
« Reply #2 on: July 10, 2008, 11:48:05 AM »
its just  a feature i don't care for and would like to disable it. :D
« Reply #3 on: July 10, 2008, 01:33:30 PM »
If you want to just disable it you could drop the trans pan and just disconnect the lead to it. I went the other way , and bought the parts to fix it! It does help with gas mileage.
« Reply #4 on: July 10, 2008, 01:34:57 PM »
You could just unplug the lock up relay.
Offline gm5226
  • 8
« Reply #5 on: July 10, 2008, 02:21:01 PM »
thats what i'm looking for but i don't know which relay controls it.
« Reply #6 on: July 11, 2008, 06:20:06 PM »
Aww hell pull em all, ur bound to find it then replace the ones that make the trucklet run
 >:D
« Reply #7 on: July 11, 2008, 08:30:47 PM »
Why?
Offline nuts4hotwheels
  • 169
  • Black Sunshine
« Reply #8 on: October 04, 2011, 03:25:36 PM »
I am getting the TCC lockup code and don't know when I can change the TCC solenoid.  Can you run it without it working or will it screw up the tranny and/or leave me stranded?
Black Sunshine
1998 4 dr Chevy Tracker 4x2 1.6L-16V
-K&N Performance Air Filter
-Thrush Glasspack -235/75-15 Pathfinder Trail A/P Tires  -Sony Xplod Cd Player -400W Visonik amplifier -2 10" Visonik Subwoofers *******************************
« Reply #9 on: October 05, 2011, 11:50:27 AM »
No, it just won't lock up the TC, I think mine quit working a long time ago
  • 169
  • Black Sunshine
« Reply #10 on: October 05, 2011, 03:53:24 PM »
OK, thanks for the answer.  I will probably still try to fix it, but now I can wait until the funds are a little better.
Black Sunshine
