Bumper Relocation.....
  • 9 Replies
  • 3003 Views
Offline Trackin_Tracker33
  • 137
  • Have Gun will travel
« on: July 14, 2008, 08:01:22 PM »
I have just installed the RockyRoad +2'' body lift. Does anyone have pictures of stock bumper relocater brakets for the 2'' body lift (front and rear)?   home made or bought     I have done plenty of searching with little result
        Thanks
I got your Jeep thang,  thats why it burns when I pee..
Mods: BDS 2" susp., Rocky Road +2'' Body, OME struts, flipped strut mount, custom High lift mount, CB, 30x9.50x15 RVT's
Comming soon.... To hell with IFS,  SAS'N it
Offline olija
  • 770
    • Check out my cardomain
Re: Bumper Relocation.....
« Reply #1 on: July 14, 2008, 09:51:02 PM »
The back is real easy. Just get 3 pieces of 2x3" tubing in 2" long sections. Drill a hole through the middle of each and put the bumper on with the top 3 bolts. For the 2 lower mounts, just get some self-tapping screws and tap into the frame. The front is a pretty complicated setup that for me, involved a fair bit of drilling and welding. Other people may have done things other ways.
Offline derekj
  • 784
  • i'm the canadian guy eh?
« Reply #2 on: July 14, 2008, 10:18:18 PM »
BDS's body lift comes with bumper brackets for the front and rear. You could see if they sell them separately.
Derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
  • 137
« Reply #3 on: July 15, 2008, 11:25:43 AM »
That doesnt sound bad at all.  Thanks for the advice
  • 137
« Reply #4 on: July 15, 2008, 11:49:38 AM »
Bumper brakets are on the way!   Thanks  ;D
Offline beercheck
  • 1215
  • Go Cards!
    • trivia-nights.com
« Reply #5 on: July 15, 2008, 01:02:14 PM »
From?
XL-7 front coils
1.5" rear coil spacers
  • 137
« Reply #6 on: July 15, 2008, 06:42:33 PM »
Well I thought thye were on there way from BDS suspension........but they called me back and said the kit is discontinued and there are no more available.    Back to square one
« Reply #7 on: July 15, 2008, 06:51:34 PM »
Let me know if you come up with something... i am in the same boat.
Offline olija
  • 770
« Reply #8 on: July 15, 2008, 10:27:02 PM »
If you have the time and access to a welder, you can drill out the spot welds on the front inner bumper so you can remove the mount arms from the bumper itself. Then you do the same trick using 2x3 tubing but you need to slot it about halfway so the upper bumper tabs go INSIDE the 2x3 tube or else the bumper will sit too high and contact the grille. Once you have the bumper securely mounted onto your 2x3 tubes you can fab up some lower mount arm extenders. Just make a 90 degree angle and cut it with a jigsaw to the shape of the bumper mount, then have it welded to the mount arm, and then hold the mount arms up to the bumper with the bottom bolt in and get someone to weld your 90* angle (now welded to the stock mount arm) onto the bottom of the bumper. I did this on mine, it looks decent but I could have done a better job. It's fairly sturdy but no ARB.
  • 137
« Reply #9 on: July 16, 2008, 02:11:41 AM »
Sounds good    Thanks for the tip        I will take a stab at it tomarrow
