why do you loose 5th gear
picklepants
42
July 18, 2008, 08:44:58 PM »
id just like to know the reason that you loose 5th gear by running bigger tires without re gearing your t case
Hillbillydave
213
Re: why do you loose 5th gear
July 18, 2008, 09:17:32 PM »
You don't actually lose 5th gear. The engine needs to run at a certain rpm to make power. They are geared to keep the engine in it's "powerband" with the stock 205/75R15 tires. If you add taller tires, you actually make the gear ratio higher due to the larger diameter. Now the motor does not reach it's optimum rpm range, and therefore can't maintan highway speeds in 5th gear. Lower gears, either t-case or axle, put the motor back in the right rpm range. Maybe I explained it, if not, someone else is welcome to correct me or add.
picklepants
42
July 18, 2008, 10:28:37 PM »
that answers my question exactly.
Uncivilized
1469
Reply #3 on:
July 19, 2008, 07:59:23 AM »
I'm up to a 31" tire with stock gearing and I still use 5th everyday. It's really nice because moving along at highway speeds I'll only rev ~3000rpm. My spedometer reads a touch over 90km/h but I'm actually travelling 100km/h.
Jeremiah
1880
Viva La ZUKIWORLD!
Reply #4 on:
July 19, 2008, 05:19:53 PM »
It's leverage. A wheel is really a lever. The longer the lever (bigger the tire), the more resistance the axle shaft (and therefore your engine) has. Then, there's the added rotational weight. Rotation weight is bad for the same reason.
chrisvitarasport94
228
Reply #5 on:
July 20, 2008, 12:44:48 AM »
make sure you have a full tune up, with perhaps best plugs and K&N type filter, so that the motor is on song, and that will help a little
just sit back and enjoy it!
Jeremiah
1880
Viva La ZUKIWORLD!
Reply #6 on:
July 21, 2008, 04:38:14 PM »
Not a fan of K&N actually:
http://www.bobistheoilguy.com/airfilter/airtest3.htm
Drone637
8121
116
Evil Cow
Reply #7 on:
July 22, 2008, 04:15:29 PM »
The K&N don't keep quite as much dust out, but they do flow a lot better. I would rather use some of the new synthetic filters but nobody has made one for the Tracker yet.
Bigzook
2206
13
Current owner of the famous Audi Kick
Reply #8 on:
July 22, 2008, 04:40:30 PM »
I lost 5th gear, then I found it again.
http://www.facebook.com/#!/pages/Donkey-Worx-Galleries/144890372136
[/url]
Hillbillydave
213
Reply #9 on:
July 23, 2008, 08:56:39 PM »
Always the last place you look.....
