Realy need help with my carb, before i destroy it!!!!
  • 2314 Views
Offline MaD.72
  • 183
  • It's not what you buy, it's what you built!!!
« on: July 22, 2008, 12:24:10 PM »
We have a 87 sammi who we decide to bring back to life!!!!
The problem is with the carb i have a couple of one here, and i decide to built one ....
First question is....what is the best number(size) for my primary and my secondary main jet, that i should use????
Second question is..... what is the primary setting for the mixture adjusting screw???
BTW im around 500 feet from sea level!!!
Offline MaD.72
  • 183
Re: Realy need help with my carb, before i destroy it!!!!
« Reply #1 on: July 22, 2008, 12:28:22 PM »
Here a picture....the arow point at the mixture adjusting screw....
Offline rascott
  • 669
  • 15
« Reply #2 on: July 22, 2008, 01:43:27 PM »
is this the mixture screw you access by removing a pin that's in the way?
that is "set" and "shouldn't" be monkeyed with without a COmeter.
i don't have a baseline adjustment mentioned in my manual.
count turns so you remember where it was?
i thought of pulling that pin when i overhauled my original carb. just so i could mess with it, but didn't.
Offline MaD.72
  • 183
« Reply #3 on: July 22, 2008, 02:15:45 PM »
I check the number of turn before i remmove it .... but there was a groove in the needle like if they had tigh it to tight???
« Reply #4 on: July 23, 2008, 02:17:16 PM »
The carb is the #1 restriction on these engines. If you live in a state that doesn't have emissions, you may want to consider taking one from another vehicle (up to about 1.8L). There are toyota carbs that are direct bolt-on, and many others can be modified, or adapter purchased.
« Reply #5 on: July 23, 2008, 02:18:19 PM »
Come to think of it, i live in Smog Nazzi Callifornia, and I've still considered the swap. As long as the install LOOKS stock, the technicians don't really care / notice.
Offline MaD.72
  • 183
« Reply #6 on: July 23, 2008, 02:48:22 PM »
 ???I have 5 same carb...well they all look alike :) anyway now im stock with this i have 3 diferent primary jet!! #108, #123 and #153 now wich one should i use???
« Reply #7 on: July 24, 2008, 11:52:35 AM »
Can you call a suzuki dealer and have them look it up?
