synthetic oil in samurai
  • 5702 Views
« on: July 24, 2008, 10:40:17 PM »
is there any problems with runing synthetic motor oil in a 1987 samurai.
is there any advantages with running synthetic in it? performace, heat, friction?
Re: synthetic oil in samurai
« Reply #1 on: July 25, 2008, 02:07:23 PM »
Maybe.
Most Samurai's leak. Especially around the distributor. If yours doesn't leak, then there's no problem. The BS about "don't use synthetic, it'll cause a leak." is just that - BS. There's a few people that claim this is true, but study after study is unable to replicate this. Further, there's no "magic" chemical that eats away sludge and causes leaks - it's just preposterous.
There's 2 main advantages of synthetic:
1) Because it's starts out with an improved "base" oil, they're able to put in a better detergent package (the chemicals that combat the formulation of sludge, shearing, acid from combustion process etc). This superior detergent package means the oil can stay in the engine longer (10,000 miles +), so you don't have to change the oil as frequently.
2) Some synthetic oils "stick" better when cold, and provide better lubrication during startup. It's unknown how much (if any) this helps engine longevity. Considering engines have lasted 200,000+ miles on conventional oil (my Celica was running strong at 264,000 miles when I sold it, and it never had synthetic in it), I have my doubts as to how much this really helps.
If you have an engine that doesn't leak, or eat oil, and you're interested in going longer between oil changes, synthetic makes sense. It can save you money by lasting 3-5x longer than conventional oil. If you change your oil every 3,000-6,000 miles, or your engine leaks / eats oil, there's no cost benefit to using synthetic. Conventional oil sold in the US is REQUIRED to last a minimum of 6,000 miles.
Offline jzap
  • 515
  • How difficult can it be?
« Reply #2 on: July 28, 2008, 02:45:48 PM »
Quote Jeremiah "The BS about "don't use synthetic, it'll cause a leak." is just that - BS. There's a few people that claim this is true, but study after study is unable to replicate this."
I don't know about causing a leak, but I had an engine many years ago, when Mobil 1 was "the" synthetic oil, that started using a lot of oil when I put synthetic in it.  I had previously always used Quaker State (or Royal Triton when I could get it), and never had to add oil between changes.  The Mobil 1 went a quart down about every 300 miles.  It didn't leak, it didn't smoke like it was burning it, it just disappeared.
I put Quaker State back in it, and went 7000 miles to the next change before it was a quart down again.  Nobody could ever explain it to me...
Jim Z.
66 Apache camper
