So I did some thinking (drawings inside)
  • 51 Replies
  • 11054 Views
0 Members and 16 Guests are viewing this topic.
Offline explosivo
  • 3157
Re: So I did some thinking (drawings inside)
« Reply #45 on: October 01, 2004, 04:25:09 AM »
The Ford's 8.8 is a well-supported axle housing in the locker and gear department. Gears are deep as 5.38's. To add, there are independent 8.8 in the rear axle applications. Check out the Lincoln's w/ ind. rear axles. (Do a search on Ebay and see what I'm talking about.) This would probably be a better idea. To add, H1 Hummers uses AMC20 axle housings.
I do have a TTB swing arm, along with ARB and 4.56's in my  TTBD44 that I've pulled from my Bronco for a SAS. I can shoot some pics on the mounting. In using such, you wouldn't need a cv at the housing end, a simple joint would work fine as the travel angle is not great enough. Then the steering joint can be a joint also and thus would eliminate the cv joint all together. Get a set of spline axles like the TTB has on the passenger side, as a spring in the splip to keep pressure of the inner axle to stay in the housing and you got a decent idea.
Military M151 'Mutt' used this concept of u-joint axles on IFS in both front and rear axles. The shaft was fixed length and the axles were full time 4wd applications.
This vehicle was a larger version of the Marine Mighty Mite which was air-cooled, near 1500#'s due to the aluminum body. The Mutt's weight is near 2000#'s.
FWIW, Currie uses the 8.8 gears for their reverse cut 9" housings.
A U-joint would have enough range of motion for the outer part with steering and all?
Ford 9" rear ends can go up to 6.50 gearing, from what I hear ;). I personally would want something more than 5.38's if I were to use a 9" and D44TTB setup, since I'd probably be able to go larger tires... something like 5.83's and dual t-cases with 38's ;)
omghi2.us[/url]
Offline 1bigtracker
  • 3409
« Reply #46 on: October 01, 2004, 04:29:10 AM »
try 9.00.  got crawl ratio? ;D
stu
Offline explosivo
  • 3157
« Reply #47 on: October 01, 2004, 04:32:01 AM »
stu
Whateva, still lower than 8.8" rears ;D
BTW, send me a 9" rear from an early bronco, please ;D
omghi2.us[/url]
Offline 1bigtracker
  • 3409
« Reply #48 on: October 01, 2004, 04:38:10 AM »
we have have tons of 3rds and truck 9's but not many early bronco 9's. :-/  got to keep spare parts you know.
stu
Offline explosivo
  • 3157
« Reply #49 on: October 01, 2004, 04:40:47 AM »
stu
Yeah, I know... I'll just do something crazy, like use the full width 9" from my truck on my tracker with the IFS at normal track-width ;D
omghi2.us[/url]
Offline jagular7
  • 1026
  • Jagular7
« Reply #50 on: October 01, 2004, 01:42:06 PM »
.....snip.....
Here is a slip shaft for part of the axle shaft for a M151. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=10076&item=2490498875&rd=1
http://members.aol.com/muttguru/page9.html
And a nice picture of the rear suspension, arm length, and axle shafts with u-joints. http://members.aol.com/muttguru/page13.html
BTW, the diffs were centered both front and rear.
Lenexa, KS
Offline explosivo
  • 3157
« Reply #51 on: October 01, 2004, 01:46:09 PM »
I bet those are pretty hard to come across, though :-/
omghi2.us[/url]
