axle strength
  • 10 Replies
  • 3107 Views
Offline pdasilva
  • 71
  • Suzuki Rules...
axle strength
« on: September 30, 2004, 12:03:21 AM »
What is the maximum tire size that can be put on a 1.6 sidekick before the axles give way.I currently have lockright lockers front and rear,and the front housing has been upgraded to steel housing .
Re: axle strength
« Reply #1 on: September 30, 2004, 03:02:23 AM »
It's not the tire size, it's
the use of the skinny pedal
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
Re: axle strength
« Reply #2 on: September 30, 2004, 07:37:06 AM »
Too many variables here. My coisin runs 35 MTRs with no breakage. Hes a crawler. I like to hammer... ::) 31s is as far as I could take stock axles. I know several guys running 32s without problems.
Mike
Re: axle strength
« Reply #3 on: September 30, 2004, 07:41:36 AM »
Ahhemm   33s  Thank you very much
Offline whitfield
  • 633
  • 4-dr Kick on 34's
Re: axle strength
« Reply #4 on: September 30, 2004, 07:48:51 AM »
I run the Alu kick front diffs on both ends of my Sammy on 38's but I don't beat on them too hard.
Offline 1bigtracker
  • 3409
Re: axle strength
« Reply #5 on: September 30, 2004, 10:05:22 AM »
i'm running 34's with lots of breakage. :-/  this winter is going to be a big one.
stu
Offline explosivo
  • 3157
Re: axle strength
« Reply #6 on: September 30, 2004, 01:32:20 PM »
stu
You also have a welded diff, goofy ;D
I've had tons of breakage up front... out back, nuffin'
omghi2.us[/url]
Offline Bfunk
  • 406
Re: axle strength
« Reply #7 on: September 30, 2004, 01:51:56 PM »
I try to be as gentle as possible and crap out rear end parts on every other run.  But it can't be the tires, because my 35" boggers don't get as much grip as.... oh let's say MTRs, right Eric?
Brian
Offline 1bigtracker
  • 3409
Re: axle strength
« Reply #8 on: September 30, 2004, 02:35:40 PM »
no, my rear is welded.  ;)
stu
Offline explosivo
  • 3157
Re: axle strength
« Reply #9 on: September 30, 2004, 03:03:00 PM »
stu
That's what I meant... I thought this thread was about the rear axle ;)
plus, skinny tires, skinny tires! ;D
omghi2.us[/url]
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: axle strength
« Reply #10 on: October 01, 2004, 01:15:06 PM »
32x11.5 MTR's  and no problem with the rear.
Has anyone tried the Calimini's new rear axils?
32 MTR's Warn 8000i
