mpg problem with a twist
  • 11 Replies
  • 3446 Views
Offline brawnyrebel
  • 131
  • i've cought a case of samuraitis
« on: August 04, 2008, 03:29:48 PM »
 I recently switched back to 3.73's from 4.62's and i have actually been paying attention to the gas mileage now. It probably has not changed much from the axel swap  but i'm only getting around 12mpg. 31's and a 4-1 case. It has a 1.6 8v swap from an obd 1 tracker, header and big exhaust. The oxegen sensor is bent at the wire end from the engine leaning on it before it was put in. Also when i wired the generic style sensor to a stock plug i had two reds and a black on the plug and two whites and a black coming out of the sensor. Does it matter which red goes to which white?
If its not broken, break it
Re: mpg problem with a twist
« Reply #1 on: August 04, 2008, 04:49:15 PM »
How are you calculating your MPG? Have you re-calibrated your odometer for the larger tires? With 31" and t-case gears, I would think you should be getting much closer to 20MPG. Maybe a little more if it's fuel injected.
Offline brawnyrebel
  • 131
« Reply #2 on: August 04, 2008, 06:13:22 PM »
The speedo is dead on with the case and 31's. I found one of the little radar trailors the cops put out and cruised by it a few times to check.  I never calculated it with the 4.62's . I would be thrilled with 20 at the moment
Offline captchee
  • 224
« Reply #3 on: August 04, 2008, 07:20:47 PM »
 have you pulled the codes ?
« Reply #4 on: August 05, 2008, 07:07:27 AM »
There's got to be something going on. I know the ECU will go into a "limp home" mode and run intentionally too rich (as it's less destructive than too lean) if it's throwing a code. Get that thing scanned.
Offline captchee
  • 224
« Reply #5 on: August 05, 2008, 01:16:07 PM »
 yep my bet is she is throwing a code  your MPG is just to low .
 my bet is that for some reason your ECM has went to limp home/ fail safe mode
Offline brawnyrebel
  • 131
« Reply #6 on: August 05, 2008, 02:41:49 PM »
 I agree that it is running in closed loop mode. It is obd1 so i flashed it and i only got the 12 code which is normal. I'm just curious if the sensor is bad but not showing a code. The egr system may not be working due to the hole inthe thorley header not lining up compleatly over the hole in the block  causing a little exhaust leak but i was told that it wouldn't cause a noticable difference. Thanks for the help so far fellas
Offline captchee
  • 224
« Reply #7 on: August 05, 2008, 03:54:16 PM »
 Buy  chance you have not taken the battery cables off  since you last  drove it for 30 minutes or so did you ?
 if so it cleared the ECM and all you will get is a code 12  tell more info is logged .
 you need a OBD scan.  take it to a dealer or local shop that can do that for you .
 if the ECM isnt shooting a code other then 12 then there is mostlike a problem with one or more of the sensors
« Reply #8 on: August 06, 2008, 12:49:29 PM »
I wonder if the ECU could be bad? Not sure how to test for this.
Offline brawnyrebel
  • 131
« Reply #9 on: August 06, 2008, 06:18:11 PM »
 I have driven it a few thousand miles since the swap. When i start it the light stays on for a moment and then goes off like normal.
« Reply #10 on: August 06, 2008, 08:36:20 PM »
The ECU doesn't always realize there's a problem & throw a code when it's broken. Just a thought.
Offline captchee
  • 224
« Reply #11 on: August 07, 2008, 08:05:46 AM »
yep very true exspecialy with older ECM's . if the sender completely dies . the ECM simply will not recourd information  and make adjustments  that the falty sender would be telling it to make .
 this is where running a OBD scan  comes in . you can eather go through and test each sendor  or have the test code run . this will tell you if a sender is not sending info to the ECM  IE its faulty or  it has a  wiring issue . there also is alot of  other issues past  bad or faulty sendors that will kick the ECM into fail safe mode . running an OBD  scan  will only give you information on the electronics . in wich case it will help you narrow down the possable problems
JT over on the suzuki forum has a good write up on this as well as how to  check the senders . he exsplains it much better then i can  and is much clearer .
 im not sure if  it acceptable to post such a link here  on this forum  though as some places frown on such things . so if you would like the link  i would send it to you in PM
« Last Edit: August 07, 2008, 08:10:19 AM by captchee »
