Biggest Tires for Smallest Kick
  • 2682 Views
Offline RifleRide
  • 29
  • Mentor a Child!
« on: September 27, 2004, 01:54:36 AM »
What is the largest tires you can run on stock rims, with 1.5 lift, on a 89 kick?
Re: Biggest Tires for Smallest Kick
« Reply #1 on: September 27, 2004, 03:21:01 AM »
235 75-15s
Offline SiKiD_01
  • 574
  • Fully Sik, Flying Vit.
« Reply #2 on: September 27, 2004, 03:57:50 AM »
even the cheese cuting 235 75 15s might rub a bit, mine did.
« Reply #3 on: September 27, 2004, 04:04:42 AM »
Just a little frame is all I ever got,
and that was at near full steeringwheel lock
Offline Jarrodl
  • 40
  • She thinks my TRACKERS sexy!
« Reply #4 on: September 28, 2004, 05:38:35 AM »
There is a size you can use that is a little larger than the 235-75-15. The 235-75-15 is supposed to be 28.9" in diameter. I run 7.00-15. They measure about 29.5+" in diameter. Some people don't like narrow tires, but these have good tread for mud. The ones I have are discontinued, but the CO-OP sells the size in a Grip Spur. Or at least they do in TN. They are an aggressive directional nylon belted heavy duty tire. They are probably designed for farm work, but they made a world of difference on my tracker. Also, at the present time, I have no lift of any kind and they don't rub even at full steering wheel lock.
96 Tracker 4x4 Automatic 2dr Soft Top
Offline 92Sidekick4x4
  • 1456
« Reply #5 on: September 28, 2004, 05:56:15 AM »
i have 30's on mine kick and it rubs only a bit when i turn all the way right btu its basiaclly at the end of my steering so they fit fine
Offline jerryp58
  • 449
« Reply #6 on: September 28, 2004, 08:36:54 AM »
I haven't done a Search, but I thought I've read some recent posts where there are people out there running 30x9.5 on stock wheels with no lift.  Was I reading that wrong ???
I know I read that people have run 30x9.5 on the stock rims and that I read in a 4x4 magazine recently that they consider 4" wider than rim width the max tire width they'd use (9.5 works fine on our 5.5" rims then).  But, I'm not positive about the "no lift" part.
Jerry
