Sidekick highway capability
  • 23 Replies
  • 7430 Views
Re: Sidekick highway capability
« Reply #15 on: August 27, 2008, 11:28:42 AM »
as i said im getting 30 with my 3 speed auto . but again its a 2 door not a 4 .
but i can say that i get  the best MPG  and power at over 3000 and under 4000
 thus this makes me feel that the engine  is set up  to run  the most efficiantly somewhere in that range
Yep, that's the power band. These engines love to rev a bit.
« Reply #16 on: August 27, 2008, 04:13:06 PM »
So how does the 4wd work in this, is it shift on the fly or do you have to stop before shifting into 4wd?
« Reply #17 on: August 27, 2008, 04:15:23 PM »
Also does someone make a reese hitch with a 2" receiver for the sidekick?
« Reply #18 on: August 27, 2008, 04:53:43 PM »
It depends.  If you have manual lockouts and have them locked in, then it is shift on the fly.  If you have auto hubs, then you have to come to a stop, before you can shift into 4wd.....unless you have shifted into 4wd previously and the hubs are still engaged, then you can shift on the fly.
Personally, I don't care for auto hubs and have swapped them out on both my sidekicks.
I have seen some with hitches....not sure who makes them though.  I made my own hitch for mine.
« Reply #19 on: August 27, 2008, 04:54:53 PM »
Calmini makes a class 1 hitch, but I think that might be to small for what  you want.  Most after market rear bumpers come with a 2" receiver installed.
« Reply #20 on: August 29, 2008, 04:08:01 PM »
Generally you have to have a bumper made, or buy one with a hitch in it.
Offline captchee
  • 224
« Reply #21 on: August 30, 2008, 08:27:36 PM »
there normal is one or two class 1  1/1/4  hitches on e-bay for sale . i believe they are 90 bucks or so . dont know that i have seen a 2 inch though
« Reply #22 on: August 30, 2008, 09:03:50 PM »
JC whitney has a 2" class 3 hitch for Trackicks.  Couldn't pull that much with one though, not enough torque.
« Reply #23 on: August 31, 2008, 09:25:25 AM »
The most it would pull would be a 5x7 trailer to pull mine and my sons atv's.
