87 sami keeps killing coils....
  • 3084 Views
Offline 90camozuki
  • 90
  • Go Hard or Go Home!!
« on: August 25, 2008, 05:43:00 PM »
Ok, I am new here. Just got two sami's as a package deal.  the one is a 87 with a msd offroad 6 ignition on it.  I have drove it many of times here lately.  It also has a msd high vibration coil on it. the other day i lost spark. so i went to the local parts house and got a 12v stock coil. put it on, fired right up and then cut it off. went to start again..no spark. thinking the coil maybe a factory defect. i took it back and got a new coil. put it on and went about 100 yards down the road....lost spark.. now i ordered a new msd hvc. but it wont be here for a week or so..... what is going on... i do not want to put my new coil on and blow it. ( $50 down the drain)  Help me if you have any ideas what the problem is. maybe something i can test..........
1997 Jeep Cherokee 2" lift,  31s, snorkel, arb bumper, roof rack, piaa lights, soon to be 4.5" super flex lift.
1973 Dodge Charger, fully restored, banana yellow...
2001 Dodge Ram 2500...work truck...
2006 Honda Pilot...wifes ride...
1998 Pontiac Grand Prix GT....Gas saver.......
Offline 90camozuki
  • 90
Re: 87 sami keeps killing coils....
« Reply #1 on: August 26, 2008, 02:13:41 PM »
a little help please
« Reply #2 on: August 26, 2008, 03:50:16 PM »
Did you test the old coils, or just take a guess and replace them? Check all your grounds - get yourself a manual, and start checking everything that's electrical.
Offline 90camozuki
  • 90
« Reply #3 on: August 26, 2008, 05:41:52 PM »
how do you test a coil?? i ask the parts house guy the same question and he said you cant test them just replace it.
Offline RHodge
  • 523
« Reply #4 on: August 26, 2008, 05:53:57 PM »
check with MSD , but I don't think there coils like a full 12v,  so if you have 12v |removethispart|@ the coil you may need to get a .08ohm resistor
http://www.msdignition.com/product.aspx?id=5023
Good luck
Offline 90camozuki
  • 90
« Reply #5 on: August 26, 2008, 05:57:31 PM »
that resistor is if i had a stock ignition with a msd coil. i got the msd ignition and it worked fine before.  i changed the plugs and wires right before the hvc went out. could that have anything to do with it??
Offline RHodge
  • 523
« Reply #6 on: August 27, 2008, 07:58:06 PM »
changing the plugs & wires should hurt anything
take a quick glance at msd's site I shaw how to check the box in the tech section
Ryan
Offline rascott
  • 669
  • 15
« Reply #7 on: August 27, 2008, 09:15:20 PM »
check the coil w/an OHM meter.
you need the specs. for the coil you are testing. an msd coil resistance is different value than stock.
also- my '89 kick does not use a resistor for the stock coil(i'm using an msd2 blaster, no resistor).
if the coil you are using is suposed to have a resistor, check and see if there is actually one there(and vise/versa).
be careful |removethispart|@what parts counter people say. listen but do some research.
