Samurai 2wd low mod?
  • 2838 Views
« on: August 26, 2008, 05:07:23 PM »
I have heard you can modify or remove something from the stock transfercase so you can put the transfercase into 2wd low as well as the other ranges. I searched but could not find any info. Anyone ever do this?
Offline 90camozuki
  • 90
  • Go Hard or Go Home!!
Re: Samurai 2wd low mod?
« Reply #1 on: August 26, 2008, 05:54:54 PM »
you can just go to ask.com and type in samurai 2wd low mod and it will bring up lots of articles on the conversion.
1997 Jeep Cherokee 2" lift,  31s, snorkel, arb bumper, roof rack, piaa lights, soon to be 4.5" super flex lift.
1973 Dodge Charger, fully restored, banana yellow...
2001 Dodge Ram 2500...work truck...
2006 Honda Pilot...wifes ride...
1998 Pontiac Grand Prix GT....Gas saver.......
Offline ROSS
  • 1412
« Reply #2 on: August 26, 2008, 06:12:01 PM »
a twin-stick will do the trick
« Reply #3 on: August 27, 2008, 09:12:29 AM »
You have to take out the center detent ball between the shift rails.  Then you can either use the single stock stick with an alternate shift pattern, or use twinsticks, to engage 2low.
Simply getting twin sticks (all they do is make it so you have an individual stick for each shift rail....one for high/low selection, the other for 2wd/4wd selection) will not allow you to access 2low....the center detent ball still has to be removed.
