steering spacer
  • 3197 Views
Offline 92Sidekick4x4
  • 1456
steering spacer
« on: September 27, 2004, 05:24:59 PM »
hey all i am going to be putting in my home made body lfit in the next few days and i have read about having to extend my steering? how is this done?
Re: steering spacer
« Reply #1 on: September 27, 2004, 05:30:14 PM »
Cut the shaft, add (weld) a section
of tube that fits snug on the shaft
Done
look past the header tube at the shaft,
you will see a welded spot where I added
some tubing, next to the turbo outlet
  • 1456
Re: steering spacer
« Reply #2 on: September 27, 2004, 05:32:22 PM »
so what will happen after i put the lift in will it be drivable with out doign this?
Re: steering spacer
« Reply #3 on: September 27, 2004, 05:38:57 PM »
No the steering shaft won't be
long enough to reach the steering box
You have to modify this after the body lift
so you know how long the added tube needs
to be
  • 1456
Re: steering spacer
« Reply #4 on: September 27, 2004, 05:41:59 PM »
ok so the sterring shaft will be out fo the box once i lift it? and then i will ahve to cut the shaft then put a peice of material to extend it?
Re: steering spacer
« Reply #5 on: September 27, 2004, 06:07:02 PM »
Yes, remove the box side of the
steering shaft before you start to
lift the body, I forgot, and it took
me 30 Min to figure out why I couldn't
push the dang body back far enough
the get my spacers in   ::)
P.S. lift the body with a floor jack, and
a large piece of board to support the
body, otherwise it wants to bend the
floor of the Trucklet up
