DUAL TRANSMISSIONS
  • 5006 Views
DUAL TRANSMISSIONS
« on: August 27, 2008, 07:38:00 PM »
I have not found much on this.I found 1 post on a Toyota dual transmission . Has any of you tried  this with manual tran`s . Got a stock sammy with a bad T case . Got T90 (Jeep) with a D20 T case .  I have all the parts I need to do this,I think .I`m going to get the drive shaft cut and have some splines installed  in the shaft . I`m using the short drive shaft off the tranny as my adaptor for the T90 tranny. I`m going to install a bearing on this for support.Would like some input . THANKS
http://community.webshots.com/user/zukezilla
« Last Edit: August 28, 2008, 06:15:28 PM by zukezilla »
Offline RHodge
  • 523
Re: DUAL TRANSMISSIONS
« Reply #1 on: August 27, 2008, 08:04:18 PM »
the problem I came up with is it's not going to give you any more reduction it's going to act like an overdrive
Offline safarikick
  • 270
  • nor-cal rhinos
« Reply #2 on: August 27, 2008, 09:08:31 PM »
« Reply #3 on: August 28, 2008, 10:25:23 AM »
http://www.suzuki-samurai.nl/volvo/volvo-eng.html
I was just going to mention that.  :)
The main issue you will run into is space and alignment.  If you can get your transmissions lined up perfectly you can skip putting the extra u-joint into between them and save yourself some space.  Then it's just a matter of making sure there is enough room to put it in and still have your drive shaft be able to reach your rear axle.
Offline RHodge
  • 523
« Reply #4 on: August 28, 2008, 10:31:43 AM »
I think I was wrong, my thoughts were clouded from the cold medaction
Ryan
Offline Hillbillydave
  • 213
« Reply #5 on: August 28, 2008, 05:11:10 PM »
Correct me if I'm wrong:
5spd in front, 4spd in rear, 2 gears in tcase
40 forward gears, 18 reverse gears 8)
Put both transmissions in reverse, rig would still move forward! ;)
definite food for thought!
« Reply #6 on: August 28, 2008, 05:52:18 PM »
This is some of the parts I have to work with. We installed the clutch center .    We are going to cut the throw out bearing shaft and add the bearing to the pilot shaft using the throw shaft for support.  A bearing housing will be mounted to this.
« Last Edit: August 28, 2008, 06:16:29 PM by zukezilla »
« Reply #7 on: August 29, 2008, 05:55:42 PM »
Here what we came up with .
« Reply #8 on: August 29, 2008, 05:57:28 PM »
Do you think this will work ?
