I need clearance!
  • 11 Replies
  • 2939 Views
Offline Cwkick
  • 888
I need clearance!
« on: September 27, 2004, 02:39:36 AM »
Went to Tuttle Creek ORV park this weekend.  Pics in Adventure Forum.  Ripped up the trans. case crossmember.  I think I am going with the Calmini kit.  The question is 2" or 3".  Not trying to start a war here.  This is a dual purpose vehicle so please keep that in mind.
Cwkick
Re: I need clearance!
« Reply #1 on: September 27, 2004, 03:20:22 AM »
Skid Plate, bigger tires, 2" lift for Dual Purpose
should be a good combo
« Reply #2 on: September 27, 2004, 04:23:10 AM »
Yea, I'm with Wild on this one. The 2" Kit will ride and handle alot better on road than the 3". You can fit 29-30" tires with little or no trimming with the Calmini 2" suspension lift. I run this kit on my daily driver and put 1000 miles a week on it with no complaints ;D
Offline Cwkick
  • 888
« Reply #3 on: September 27, 2004, 05:00:58 AM »
Ya, Zukipilot your X looks good.
I had a Calmini 2" kit probably 10 years ago.  They have changed it though.  There was no front axle drop and they used KYB shocks all around.  It was a nice kit.
Cwkick
« Last Edit: September 27, 2004, 05:01:20 AM by Cwkick »
« Reply #4 on: September 27, 2004, 05:13:47 AM »
Cwkick
Thanks, I bought mine around 1995-1996. It spent many hard years on the Kick then was moved over to the X-90. Being able to pound the hell out of a Kit off road for many years, and then still be able to put it on a daily driver and run 80 down the interstate says alot about the quality they put into it. I love that Kit.
Offline Cwkick
  • 888
« Reply #5 on: September 27, 2004, 08:47:14 AM »
Okay!
I said F**K IT and ordered the Calmini 2" lift.
It will be here next Tuesday.
I can't wait!!   ;D ;D ;D
Cwkick
Offline suzukiboyoz
  • 194
  • Friends don't let friends ride a Yamaha
    • http://community.webshots.com/
« Reply #6 on: September 27, 2004, 09:24:46 AM »
That transfere case crossmember is a bugger just replaced mine and are fitting the Calmini Skid Plates.
3" lift is the next mod :)
Calmini 3" Suspension Lift, Calmini Skid Plates, Calmini Rockhoppers, 30" Mud TYres, ARB Bullbar, Rear ARB Locker, Custom Sill Sliders, Rear Bumper and a lot more.
Offline Cwkick
  • 888
« Reply #7 on: September 27, 2004, 09:51:27 AM »
I was able to straighten mine a bit but it is pushed up about 1.5 inches
Cwkick
« Reply #8 on: September 27, 2004, 10:26:26 AM »
2 words
SKID PLATES ;D
Since I put these on I feel alot better dragging over rocks. ;D
trees, stumps, smaller cars, etc.etc......
« Last Edit: September 27, 2004, 10:27:19 AM by trickker »
Offline explosivo
  • 3157
« Reply #9 on: September 27, 2004, 10:57:16 AM »
Man, you don't need no stinkin' skidplates... just do it Palmberg style and get 'mog axles and 44" boggers...  Drive right over top of everything 8)
Yeah, the 2" kit would probably be much better for a daily driver/trail rig than the 3".
omghi2.us[/url]
Offline jagular7
  • 1026
  • Jagular7
« Reply #10 on: September 27, 2004, 11:28:00 AM »
You could actually go with the 2" suspension add your slightly larger tires, work out the bugs for better droop on the 2", and when you are ready for larger tires, gears, lockers, etc, add body lift.
Lenexa, KS
Offline Cwkick
  • 888
« Reply #11 on: September 27, 2004, 03:03:01 PM »
Jag,
You and I are always on the same page.  After some armor, I'm thinking about the Rocky-Road 2" body lift.  Talk about opposites attracting.  Calmini lift + Rocky-Road lift.   :D
Cwkick
