Is this block toast?
  • 12 Replies
  • 3556 Views
Offline daddyizzle
  • 728
  • Colorado is still my home!!
« on: August 31, 2008, 08:48:17 AM »
Out of an 88.5 Samurai, miles unknown. Appears never rebuilt. #1 cylinder -piston locked up. Threw the rod I guess since the rod was broke in two. Looks like a hole into a coolant channel at the bottom of the cylinder wall. Is this repairable or just toss it?
In the second picture, It's the hole on the left side of the cylinder wall about the middle of the picture. You can also see some bang marks from the connector wall that are just cosmetic. The hole is the concern so I wanted to check here before I toss it unless it's worth something for the aluminum.
-Adam
« Last Edit: August 31, 2008, 08:51:36 AM by daddyizzle »
Re: Is this block toast?
« Reply #1 on: August 31, 2008, 11:25:05 AM »
I would say yes it is toast. Block's are cheap and I would not chance it.
Offline ROSS
  • 1412
« Reply #2 on: August 31, 2008, 12:40:48 PM »
if you have a small fishing boat you now have an anchor
Offline jeff1997
  • 1228
  • 27
« Reply #3 on: August 31, 2008, 02:00:02 PM »
Scrap aluminum prices are up today  ???
3" Masterkit1 body lift
Custom strut spacers
Offline HOGCAT
  • 20
« Reply #4 on: August 31, 2008, 07:25:49 PM »
  Too bad your so far away.  I have a fresh short block I am going to get rid of cheap!!!
Offline Hillbillydave
  • 213
« Reply #5 on: August 31, 2008, 08:13:08 PM »
I wish everyone wasn't so paranoid about their location, I could use a new short block as well. I am in Hope Hull, Alabama.
Offline ROSS
  • 1412
« Reply #6 on: August 31, 2008, 09:12:38 PM »
you can ship an entire 1.3 or 1.6 8v  UPS. sent one that way to so. cal.  to reynolds machine once.
Offline daddyizzle
  • 728
« Reply #7 on: September 01, 2008, 07:45:06 AM »
Thanks for the replys. I don't really need it but thought I would pass it on to someone if it was usable. I was pretty sure it was toast but thought I would check. The crank also has a severe gauge where it spun the bearing. I think it's toast too.
If I were going to ship a block like this, I think they are pretty cheap fed-ex ground by the way.
-Adam
phloop
« Reply #8 on: September 01, 2008, 08:16:49 PM »
Thank you. :laugh: And I didn't start it this time. >:D
Offline pepatt
  • 174
« Reply #9 on: September 02, 2008, 09:41:42 PM »
I may have gone a little over board on mine!   ;D ::)
pepatt
Offline daddyizzle
  • 728
« Reply #10 on: September 08, 2008, 03:25:03 PM »
Orient, Ohio 39?50'36.46"N 83?07'39.45"W
Not if you want someone to know where to guide a missle. :o
  • 213
« Reply #11 on: September 08, 2008, 05:32:16 PM »
Now that's a location!!!
Offline jeff1997
  • 1228
  • 27
« Reply #12 on: September 08, 2008, 06:09:30 PM »
He still did not include the zip code  :laugh: The post office cannot deliver to long. and lat.  :police:
