Getting ready to start the sas
  • 12 Replies
  • 3273 Views
« on: September 01, 2008, 11:58:39 AM »
here it is my festiva with 4 wheel drive
Offline Hillbillydave
  • 213
Re: Getting ready to start the sas
« Reply #1 on: September 01, 2008, 02:07:41 PM »
I will be watching intently...by the way, anybody else notice that it is already September 2 in Michigan? Must be a future build!! :D Seriously, I look for ward to seeing this build since I will probably end up doing this myself.
Offline Shredder
  • 389
    • Me & My Rig
« Reply #2 on: September 01, 2008, 07:32:18 PM »
Good luck on your project. I just fabbed up a bolt-on (option to weld) "kit" for my SWB Tracker. It is turning out better than I thought it would. It uses YJ springs with toyota PU axles. I tore it back down to get everything painted. Should be putting it back together this week or weekend and will be shooting some pictures.
Looking forward to watching how yours comes along.
I'm also from Michigan.  ;)
Offline kubik1981
  • 232
  • Drive it like You stole it. Then fix it.
« Reply #3 on: September 01, 2008, 08:09:58 PM »
I also am from michigan
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #4 on: September 02, 2008, 07:43:53 AM »
I'm in Goodrich, it's off of 15 just south of Davison or north of Waterford.
Or
Just south east of Flint.
32 MTR's Warn 8000i
« Reply #5 on: September 02, 2008, 11:53:11 AM »
hey guys thanks for the feed back. That is the 89 kick i picked up for 350.00 and changed the head. It had two burnt valves. As for the wide track dana 30 and 44 in the second pick they are not going to be used anymore just the suspension. I can not get the 5.89 gear set i want for the dana 30 5.38 is the lowest they go. I live in northern michigan Roscommon to be exact so if you guys get up north wheeling give me a shout. Jason
« Reply #6 on: September 02, 2008, 11:54:24 AM »
oh yea check out the leaves on the kick already. more pics this weekend.
« Reply #7 on: September 03, 2008, 12:32:36 PM »
What do you guys think about building something like this?
« Reply #8 on: September 03, 2008, 01:29:28 PM »
Offline Amilla
  • 1076
« Reply #9 on: September 03, 2008, 04:10:51 PM »
That thing is about 10" to high.  Other than that it looks pretty cool.
Amilla
« Reply #10 on: September 03, 2008, 04:28:31 PM »
 8) Both are pretty badassed.  Wow, all these "Ganders" in one spot. I'm origanally from the Detroit area.
I say you build it closer to the Yellow Tracker over here: http://www.zukiworld.com/month_050106/feature_moab2006_wmovies.htm
Specifically, http://www.zukiworld.com/month_050106/images/final_cut/Golden%20Spike%20182.jpg
Offline bzzr2
  • 1011
« Reply #11 on: September 04, 2008, 07:21:10 AM »
that red sami has unimog axles if i'm correct, sick!
09 taco reg cab short box 4x4
« Reply #12 on: September 05, 2008, 10:12:03 AM »
wow that yellow kick is more my style it could maybe pass for street legal around here. any tech on it?
