how do you replace CV boots in a Vitara?
  • 5898 Views
Offline SiKiD_01
  • 574
  • Fully Sik, Flying Vit.
« on: September 26, 2004, 08:05:10 PM »
i need to replace one of my CV boots, namely a left hand side inner (passenger side). i've taken the drive shaft off the vitara, and its sitting on the workbench.
even though we drive on the other side of the road, i think mechanically vitaras are all the same.
so how do you take the old boots off, and put the new ones on? i'm not sure if you have to take the driveshaft apart (CVs) or not, or is there a clip that holds everything together?
i should have asked this before i took the driveshaft off the vitara, as i'm stuck with no car tonight, and i don't really want to pay anyone to do it for me tomorrow.
thanks for any help.
Steve
Re: how do you replace CV boots in a Vitara?
« Reply #1 on: September 26, 2004, 08:20:04 PM »
 ;D Just diving right in huh ???
On the inner side, there is a retainer
clip that holds the inner CV assembly
to the shaft, you will need snap ring
pliers to remove it the right way, a screw
driver will work in a pinch, careful to
not break the clip, once off the CV parts
can be removed from the shaft, it might
hang up, a light tapping will help.
once the CV cage and inner is off the shaft,
you can slide the old boot off, and replace it,
you can reuse the clamps that hold them on,
but it's a pain to open them up again.
You can use a pair of end nippers to squeeze
the new clamps in place, but make sure the
clamp is kind of tight before you squeeze it or
it can be too loose and let dirt/water in
Good Luck
BTW the outer boot has to be replaced the same
way, just slide it all the way down, big end first
Offline SiKiD_01
  • 574
« Reply #2 on: September 26, 2004, 08:26:23 PM »
CHAMPION!
it's dark now, so it'll have to be tomorrow morning.
thanks again, didnt really expect an answer this quick.
Offline SiKiD_01
  • 574
« Reply #3 on: September 26, 2004, 08:52:38 PM »
hey wild,
which side is the clip on?
there is some sort of cap on the end (diff side) how do i get this off??
Offline SiKiD_01
  • 574
« Reply #4 on: September 26, 2004, 11:57:18 PM »
 thanks Wild, got it done.
« Reply #5 on: September 27, 2004, 02:56:45 AM »
You found the wire retainer, that is
what I was talking about if you have
too much lift, and too big of a strut
spacer, the CV balls will hit on the
wire and put dents in it.
For ease of trail changes, I leave the wire
retainer out, it's just there to keep the CV
shafts together as an assembly
