HELP!!! Is it a 4 speed or is it a 3 speed???
  • 2782 Views
Offline olija
  • 770
    • Check out my cardomain
« on: September 04, 2008, 10:48:04 PM »
I was looking to buy a 1993 Sidekick 4 door with an automatic transmission, then swap the diff gears to 5.13's to run 31's comfortably. HOWEVER, I just found out that the 4 speed auto already has the 5.13 diff gears!!!!! :-[
I was all ready to buy this rig as it is in mint condition and I even put a $200 deposit on it. Please, PLEASE tell me this thing is a 3 speed:
Any way to tell by looking at the shift handle? It also had some sort of "Power Mode" button that made it shift at higher RPM's. Thanks, Austin
Offline pepatt
  • 174
Re: HELP!!! Is it a 4 speed or is it a 3 speed???
« Reply #1 on: September 05, 2008, 06:12:48 AM »
I may be wrong, but I if I remember correctly the 4-speeds have 1, 2, D, and OD on the shifter. Also, the Power Mode button is not on the 3-speed.
pepatt
« Reply #2 on: September 05, 2008, 07:02:01 AM »
It's a 4 speed.
« Reply #3 on: September 05, 2008, 09:48:09 AM »
Ha!  I found the good post.  Just took me a while.  :)
http://www.zukiworld.com/forum/index.php?topic=21962.msg182972;topicseen#msg182972
89-98 Trackick gear ratio
89     2dr 1.3L carb 5speed man. 5.625
89-95 2dr 1,6L TBI 5speed man. 5.125
89-95 2dr 1,6L TBI 3speed auto. 4.625
91      4dr 1.6L TBI 3speed auto. 4.625
91      4dr 1.6L TBI 5speed man. 5.375
92-98 4dr 1.6L MPFI 5speed man. 5.125
92-98 4dr 1.6L MPFI 3speed auto. 4.30
92-98 4dr 1.6L MPFI 4speed auto. 5.125
94-98 2dr 1.6L MPFI 5speed man. 5.125
94-98 2dr 1.6L MPFI 3speed auto. 4.30
94-98 2dr 1.6L MPFI 4speed auto. 5.125
96-98 X90 1.6L MPFI auto or man. 4.625
4.625 gears have an 8/37 tooth count
4.30 gears have an 10/43 tooth count
5.125 gears have an 8/41 tooth count
5.375 gears have an 8/43 tooth count
5.625 gears have an 8/45 tooth count
« Reply #4 on: September 05, 2008, 10:17:25 AM »
There are a couple of revisions (deletions, actually) I need to make to my list.....
I don't believe those body style/tranny combos were ever available, so they can be removed from the list.
