HELP ME! Strut mount flip
  • 15 Replies
  • 4016 Views
Offline bandit86
  • 1641
  • elv8rguy
« on: September 25, 2004, 08:44:39 AM »
I just put the 2 inch spring spacer in, now I tried to flip the strut mount, but I didn't gain anything... how do you do it?
Offline rakkasan
  • 32
Re: HELP ME! Strut mount flip
« Reply #1 on: September 25, 2004, 10:11:29 AM »
If you turn the mount upside down from its original position and bolt it on under the mount area, you have to gain the heighth of the spacer. I didn't measure mine but it is at least 1 1/2".There are probably others, but a good picture can be seen on Zuwarrie.com BBs, Topic 8105, Aug 9  04. If you have any trouble on this, pm me and I'll scan the stuff I have.. ;)
Offline explosivo
  • 3157
« Reply #2 on: September 25, 2004, 10:38:44 AM »
You'll gain some travel, but it'll be noticeable if you have a spacer on the strut comparitive to the one you have on your spring... flipping the mount would only give like an inch of spacing...
omghi2.us[/url]
Offline DirtDevil
  • 317
  • Island4x4.com
« Reply #3 on: September 25, 2004, 12:13:47 PM »
yea with 2 inch coil spacers make another 1" thick spacer on top of the strut mount flip, i used 2 inch spacers on jens tracker and did the flip but i need another inch of spacing, ive yet to do that, and i probably should asap haha
Offline bandit86
  • 1641
  • elv8rguy
« Reply #4 on: September 25, 2004, 01:14:19 PM »
I'm surprised noone told me that a 2 inch thick spacer would create horrible driveshaft angle.  I put the 2inch spacers in, did the strut mount flip with a 1/4 inch spacer and the strut was fully extended when the truck was level on the ground.  so out came half the spacer.  no wonder you guys are worried about driveshafts, especially when approaching 30 degrees normal angle.
Offline DirtDevil
  • 317
  • Island4x4.com
« Reply #5 on: September 25, 2004, 01:58:46 PM »
on the cv shaft?? the angle in the tracker I lifted wasnt to bad atall, and only with the strut mount flip the struts are not fully extended sitting level, they have about another inch or so to come out
« Reply #6 on: September 25, 2004, 03:15:15 PM »
A 2" spring spacer lifts the front
3" from stock, it's a lever and a
compound lift on the front, you
would need a 3" strut spacer
just to be back at normal strut
positioning in the travel range.
Offline bandit86
  • 1641
  • elv8rguy
« Reply #7 on: September 25, 2004, 03:23:59 PM »
thats all fine about the lift, but I highly doubt it's any good for extreme offroad driving.  That would highly stress the cv joints.
« Reply #8 on: September 25, 2004, 03:49:18 PM »
Look at the avitar, this is the setup I
use, and have had installed for 10 years.
I think this is a very capable extreem
offroad system, CVs have never been a problem
Offline rakkasan
  • 32
« Reply #9 on: September 25, 2004, 04:29:07 PM »
OOP's,, How about this drive shaft angle after the 2" susp. lift ?..Before I installed mine , I didn't see it mentioned as a problem in all the topics I had read up on..Wa Hoppen  :o
« Reply #10 on: September 25, 2004, 04:59:52 PM »
Drive Shaft, or front CV shafts ??
I have a rear spacer for the DS that
points the yoke directly at the T-case
Front Cv shafts, can take the extra angle
OK, if you don't drop the front Axle Housing
the CVs have to take up the angle.
Again CVs have never been a problem
Offline rakkasan
  • 32
« Reply #11 on: September 26, 2004, 04:18:00 AM »
yea,,I am concerned about the drive shaft angle.. Of all the 2" susp. lifts I've noticed people have put on, I haven't heard any problems with it...?
Offline DirtDevil
  • 317
  • Island4x4.com
« Reply #12 on: September 26, 2004, 06:16:45 AM »
yea those CV's can take a good beatin thats for sure, so far they've survived the van isle trails just fine!
Offline rakkasan
  • 32
« Reply #13 on: September 26, 2004, 07:31:42 AM »
Hey DD,,What is your experience or ideas about the drive shaft angle from the t case to diff. after the 2" sus. lift? Any problems?.
Offline DirtDevil
  • 317
  • Island4x4.com
« Reply #14 on: September 26, 2004, 08:08:46 AM »
in the rear? nothin, havent seen any probs yet, in the year i have 2 1/4" spacers in
