blowing white smoke
  • 2404 Views
Offline brace
  • 264
  • I built it; I break it; I fix it.
blowing white smoke
« on: September 24, 2004, 02:40:20 AM »
I just swapped my intake manifold and carb for a new set because it was runnng rough.   And now white smoke (burinng coolant is what my mechanic calls it) is coming out like crazy.  It's running great but smoke is pouring out.  Any suggestions?
94 Escudo, 1.6 ltr 16v, 1.5" spacer lift, 31's
Re: blowing white smoke
« Reply #1 on: September 24, 2004, 03:11:08 AM »
Use a new intake gasket, and replace
it, also use some Permatex Copper Spray
gasket sealer, it looks like copper spray paint
Expensive, like $6 a can, but works well
Unless you have a problem with the new
manifold where there is a breech in the
coolant passage, then you need to swap parts
Offline steveofrost
  • 457
  • '91 SS JLX 4-Door
« Reply #2 on: September 24, 2004, 03:56:20 AM »
Heh, blowing white smoke... for a moment there I thought this was a Water Cooler post... ;D
steveo
JDraper
« Reply #3 on: September 24, 2004, 11:49:03 AM »
Yep, new intake manifold gasket would be my guess.
Offline explosivo
  • 3157
« Reply #4 on: September 24, 2004, 11:52:23 AM »
I forgot to put a bolt on my manifold once, and it blew white smoke when it got up to temp.
omghi2.us[/url]
Offline bandit86
  • 1641
  • elv8rguy
« Reply #5 on: September 24, 2004, 01:45:42 PM »
cracked the aluminum head by overtightening a bolt
Offline 1bigtracker
  • 3409
« Reply #6 on: September 24, 2004, 02:21:18 PM »
head gasket rotted out of mine
stu
Offline Mike71
  • 1449
« Reply #7 on: September 24, 2004, 02:22:28 PM »
that can happen but from what my dad tells me ( a wrencher for life lol) it is mainly when the engine is hot.i can happen when its cold but *normally* common sense kicks in before u have cracked it
