samurai bogs/stalls when you let the clutch out
  • 4209 Views
« on: September 18, 2008, 08:27:29 PM »
its an 88 sukuki samurai 1.3..... revs all the way to rev limiter with clutch in...then if you let the clutch ou t  ( put the motor under load) it starts bogging and stalls.... any ideas    ???     im a newbie with this samuari... 8)  thanks   jon
Offline Gary_Hill
  • 288
Re: samurai bogs/stalls when you let the clutch out
« Reply #1 on: September 20, 2008, 04:42:31 AM »
fuel starvation...assuming your not trying to take off in 4th gear   :)
Offline Vagabond
  • 95
« Reply #2 on: September 20, 2008, 08:09:59 AM »
Release the parking brake?
[/url]
95sidekick
« Reply #3 on: September 20, 2008, 04:16:02 PM »
sounds like either in 4th or ebrake on...even if it doesnt look like its on check see if its ceased on??
Offline zukizuki07
  • 251
« Reply #4 on: September 20, 2008, 06:38:33 PM »
where does your clutch engage?
96 2 Door Tracker
Offline Gary_Hill
  • 288
« Reply #5 on: September 20, 2008, 10:36:53 PM »
OK... just funning you. We need more info. Since you have had the Sam, has it ever ran normal. Do you have a Webber carb on it? It could be a spark problen also. ..weak coil...bad wires.... cracked dist cap. Check the condition of all you can and give us more info...
Offline mrhawk
  • 130
  • I Love ZUKS
« Reply #6 on: September 21, 2008, 02:17:38 AM »
Add a thick ground wire from the engine to the battery and the body, your engine may be grounding itself through the clutch wire.
Offline zukizuki07
  • 251
« Reply #7 on: September 21, 2008, 08:50:21 AM »
+1 check the grounds to the firewall
96 2 Door Tracker
Offline kubik1981
  • 232
  • Drive it like You stole it. Then fix it.
« Reply #8 on: September 22, 2008, 08:46:06 PM »
maybe your tranny is stuck between grears?
