Suzuki Grand Vitara, Vitara, Chevy Tracker (Gen. 2 Platform) 1999-2005
(Moderator:
ebewley
Steering issue, any ideas
toofaroffroad
226
2
I Love ZUKIWORLD!
September 22, 2008, 10:58:05 AM »
I'm getting a serious shuddering in my steering wheel from around 40 mhr to 55mhr. I have recently had the tires checked and balance and also had an alignment done. Any ideas what this could be?
1badzuk2
89
Re: Steering issue, any ideas
September 22, 2008, 03:02:21 PM »
mine did the same thing i had to have another aligment and that fixed it up or you might have bent a bar...
built sammy locked front an rear full roll cage 6 5 1 tc gears 96 16v motor and alot alot of mods
Yankee-Tim
562
September 23, 2008, 12:40:04 PM »
Didi u check the bearings?
Armour
360
Reply #3 on:
September 23, 2008, 09:03:13 PM »
Front struts could be worn out!?!?!
89 Sidekick. 33's. Lincoln Locker,4.24 T Case, 5.13 gears. Warn M8000 winch.
blacknight
987
Reply #4 on:
September 25, 2008, 09:50:21 AM »
did this start after haveing the tires checked and balance and alignment. Did they rebalance the tires? Did you try swapping the the fronts for the rear? Check for missing wheel weight, the ball joints, tie rod, wheel bearings, and struts.
George
beercheck
1215
Go Cards!
Reply #5 on:
September 26, 2008, 06:36:12 AM »
Almost killed my brother with loose lug nuts once.
XL-7 front coils
1.5" rear coil spacers
235/70-16 Bridgestone Destination A/Ts on stock XL-7 Alloys RRO Rock Rails (Presently removed, as they rusted to all hell; all the bolts were rusted to dust. Real nice, RRO...)
http://www.trivia-nights.com
toofaroffroad
226
2
I Love ZUKIWORLD!
Reply #6 on:
September 29, 2008, 09:45:18 PM »
It was inner tie-rod ends. They were warn out on the ball joint. Made it shudder on the highway, thanks
