replacing donuts...
  • 9 Replies
  • 3002 Views
Offline jzap
  • 515
  • How difficult can it be?
replacing donuts...
« on: September 23, 2008, 08:30:40 PM »
On my 96 Tracker, the joint between the exhaust pipe flange and the catalytic converter is spring loaded.  Two long bolts thread into the flange on the exhaust pipe, and the joint is held together by springs on the bolts.
Does anybody know if there is enough play in the joint to be able to pry it apart and remove and replace the donut gasket inside the joint?
Jim Z.
66 Apache camper
Offline Armour
  • 360
Re: replacing donuts...
« Reply #1 on: September 23, 2008, 08:41:38 PM »
No that is not possible! What is wrong with just unbolting it and replacing the gasket like normal people!LOL!
Offline jzap
  • 515
« Reply #2 on: September 24, 2008, 04:03:34 AM »
Typical...  bolt ends fused into solid mass of rust...
Guess its break em off, drill em out and retap???
So, Why is the joint spring loaded and not bolted down solid?
« Last Edit: September 24, 2008, 04:06:10 AM by jzap »
Jim Z.
66 Apache camper
Offline pepatt
  • 174
« Reply #3 on: September 24, 2008, 04:53:37 AM »
Blue-tip wrench.  ;D
It is a high vibration version of a lock nut.
pepatt
95sidekick
« Reply #4 on: September 24, 2008, 08:22:43 AM »
heat the bolts by the thread till they GLOWING RED smash a socket on the head an it will come out like butter
Offline jzap
  • 515
« Reply #5 on: September 24, 2008, 07:11:09 PM »
Thank you.  I'll try it that way...
Jim Z.
66 Apache camper
Offline Uncivilized
  • 1469
    • Car Domain
« Reply #6 on: September 24, 2008, 07:51:53 PM »
They're usually not very tight, the spring holds the pressure. Take a wire brush to them and give it a go. If you do drill, you don't need to tap, just drill the hole big enough so the nut is gone, and buy new spring bolts - they usually come with nuts, then use a big washer :D
Offline ROSS
  • 1412
« Reply #7 on: September 24, 2008, 08:05:41 PM »
PB-BLASTER
Offline Fordota
  • 40
« Reply #8 on: September 24, 2008, 08:57:49 PM »
or just heat and let cool then you may not have to ruin the nuts if possible
« Reply #9 on: September 25, 2008, 03:49:37 AM »
The joint is flexable to allow movement between engine and exhaust system. Ever watched your motor move around when you juce the throttle?
Also, it allows for different expansion rates between the various exhaust components as they heat up and cool down.
