got a ? for zuki gurus
  • 2621 Views
Offline hawaiizuki13
  • 51
« on: September 25, 2008, 01:27:49 PM »
ok heres the thing i noticed i got no stabilizer bar in the front and a reg steering system on the front also it have a drop pitman arm but i got spoa and 3 inch spring i noticed alot of bump steer and swaying of the jeep if i got a hi steer and find a stabilizer bar would this help alot? thanks guys for your time to answer aloha ;D
LOVE TAKING A ZUK RIDE WITH MY FAMILY
Re: got a ? for zuki gurus
« Reply #1 on: September 25, 2008, 01:38:00 PM »
By a stabilizer bar do you mean a Steering Stabilizer or do you mean a Sway Bar?
It sounds like you have an 8" lift.  I would recommend switching to a High Steer setup, that should take care of most of your bump steering issues.
  • 51
« Reply #2 on: September 25, 2008, 01:40:38 PM »
yes sway bar sorry im kinda new to this bub also would your recommend a body lift? but yes i just ordered a hi steer as we speak ;) thanks bud
« Reply #3 on: September 25, 2008, 02:44:38 PM »
No, I wouldn't recommend a body lift.  I'm not a big fan of them myself.
You should have plenty of lift the way you are.  Unless you are planning on running 35-38" tires there shouldn't be any need to go higher.  The Sway Bar might help with body roll around corners but usually doesn't help to much with the bump steer problem.
I just put a steering stabilizer back on my SJ after running for years without one.  The new tires are a bit out of balance when most of the air is let out of them, I'm hoping this fixes that issue.
  • 51
« Reply #4 on: September 25, 2008, 02:47:46 PM »
yeah i dont want a body lift either but yeah ill see when i put in the hi steer thanks bro
Offline Amilla
  • 1076
« Reply #5 on: September 25, 2008, 06:47:37 PM »
How big of a tire are you running or trying to run?
It doesn't sound like you need a body lift at all.
Amilla
  • 51
« Reply #6 on: September 25, 2008, 07:04:05 PM »
at biggest 33's but now i got 31's i just want it for looks >:D i just want to fully clear the tires i like that look i dont like the stuff look lol
Offline locjaw
  • 2045
  • 22
« Reply #7 on: September 26, 2008, 07:29:12 AM »
if we are talking about a samauari, you will need to "clearance" the wheel wells a little. some people cut and fab, some use BFH, both cases work. what helps also(and i have no idea what lift your running) is to try to move the front axel forward a couple inches. the YJ spring kit does this. i have also seen people redrill the pilot hole on the spring pad. both will dramaticly reduce tire rub. or just but tires from americas and get the warranty :laugh:
good luck
Offline idaholwb
  • 772
« Reply #8 on: September 28, 2008, 08:02:32 PM »
 If you have 3" lift springs and a spring over you have enough room for 33's, 34's, possibly 35's depending on how aggressive of tires you want to go.
97 Sport
265/70-16s
2" lift
2.0 swap
