head gasket again
  • 1834 Views
Offline RACER X
  • 383
  • zuki or die!
head gasket again
« on: September 30, 2008, 06:45:17 PM »
so I'm finally ready to tackle this head gasket my rigs a 98 16 valve 1.6 liter two door auto no a/c
so does any one have a good write up i have the fact service mags and the Hines which i was told was wrong on top dead center so any one have any knowledge of a write up or any expertise on this subject ??????????????  I'm a Lil afraid as this is the furthest Ive ever broken down this engine I have the gaskets and a good torque wrench also the timing belt and water pump but i feel I'm forgetting something... what else .........???
« Last Edit: October 01, 2008, 06:12:48 AM by RACER X »
98 kick
Re: head gasket again
« Reply #1 on: September 30, 2008, 10:44:41 PM »
I Think the Head Bolts are tty bolts so you may need to buy some.
« Reply #2 on: October 01, 2008, 04:29:46 PM »
I just finished mine and there are a few things you will need.  I used anti seize on all of my bolts, you will need a head gasket kit ($100), you may need a timing cover so check if yours is good, throw in a new thermostat since the coolant will be drained and you will have the gasket.  The most important thing is to locate a nearby shop that works on heads as you will want to get yours checked and the exhaust valves are probably toast
Offline pepatt
  • 174
« Reply #3 on: October 02, 2008, 05:07:04 AM »
pepatt
