A/C Fuse?
  • 1653 Views
Offline Rodzilla
  • 66
  • PURA VIDA!
A/C Fuse?
« on: October 07, 2008, 07:20:50 PM »
Whats the correct size of fuse for the A/C (the holder is under the hood), mine burnt up so bad I cant tell, and possibly it was incorrect to start? Thanks
'95 SideKick w/OME Suspension Lift, Calmini BodyLift, Shrockworks Bumper, ARB Rear Locker, Pro-Comp Wheels/Tires, Calmini Rear Bumper, Calmini Rear Axles
Re: A/C Fuse?
« Reply #1 on: October 08, 2008, 05:52:13 AM »
I'm pretty sure it's a 25 amp fuse. That happened to mine, and it turned out to be the condenser fan wires grounding out against the bodywork in the front, right behind the grill. You'll have to remove the grill to check the wiring.
Offline Rodzilla
  • 66
  • PURA VIDA!
Re: A/C Fuse?
« Reply #2 on: October 08, 2008, 01:05:37 PM »
Thanks,,i'll look into that.
Re: A/C Fuse?
« Reply #3 on: October 11, 2008, 05:31:55 AM »
Did you ever find out what was blowing your fuse?
