hard brakes in the morning?
  • 2314 Views
Offline mike5721947
  • 545
« on: October 11, 2008, 05:08:12 PM »
ok... been having this problem for a while, only happens when its cold. brakes are manual for a couple minutes in the morning or if its cold out then i get the power back. its getting colder out now and its doing it more and more, so its going to have to get fixed soon...
1990 suzuki sidekick, 2dr, 1.6 8V stock brakes. been thinking maybe its a bit of water in the brake fluid and its freezing in the line?
31" kumhos 3inchs of lift.
Offline karl214
  • 228
Re: hard brakes in the morning?
« Reply #1 on: October 11, 2008, 09:02:58 PM »
   I've had the same problem with both of the trackers I've had.. I'm thinking it's a condensation issue, but I may be wrong....
Rust in Peace Black Bugger..1994 sidekick... Planing on a Digger"donuts" and 3 inch bodylift, topped off with 31x10.50's in the spring.New D.D 90 softtop lilblue with the heart of black bugger
Offline Armour
  • 360
« Reply #2 on: October 12, 2008, 12:37:36 PM »
Ant experience I have had with condensation is the brakes grabbing the first couple time you apply them!
Offline Hawkeye Huey
  • 92
« Reply #3 on: October 29, 2008, 02:15:42 PM »
Hey just passing this on.... I have a 90 1.6 8v. It had hard brakes in morning. I recently adjusted the valve lash and the hard brake issue is gone. who knows...give it a try.
1990 GEO Tracker hardtop, 3" bod, 3.5"susp, rebuilt engine, Hawk SS torquer cam,Thorley tri-y 2 1/2" pipe, TT rockmonster T-case, Lockright F/R, 5:38 R/P, Pro-comp series 51 wheels 31" GY MTR's
Offline derekj
  • 784
  • i'm the canadian guy eh?
« Reply #4 on: October 29, 2008, 10:17:08 PM »
When you say cold do you mean freezing? If so you could have ice forming in your brake booster. Have seen it a few times on cars up here(north).
Derek
91 Sidekick jx
2" BDS supension lift
2" BDS body lift
1" Coil spacers
Offline mike5721947
  • 545
« Reply #5 on: October 30, 2008, 04:56:52 AM »
might be classified as freezing... 5* and down usually triggers it.
