I need some help with my new suspension setup.
  • 0 Replies
  • 1402 Views
Offline 95Gstman
  • 78
« on: October 13, 2008, 06:17:45 PM »
Okay, here is the question. I have the calmini 2" suspension system installed on my 1990 2dr vert sidekick. (OME struts, DT shocks.)  I recently added a 1.5" coil spacer to the rear and will be adding OME light duty springs to the front netting about 3.5" of lift. My question is do I need to add a spacer to the 3rd link in the rear? And if I do, do I then need to add a driveshaft spacer? I have read that the 3rd link spacer needs to be up and out so to speak and that necessitates the need for the d-shaft spacer. So will I have any problems running 3.5" of lift without addressing the 3rd link and d-shaft?
