clutch question
  • 2711 Views
clutch question
« on: October 16, 2008, 08:57:09 PM »
i have a 87 samurai clutch went out put a autozone clutch in lasted 2 times off roading whats the best clutch to get.
It is lifted with 33 boggers thanks
Re: clutch question
« Reply #1 on: October 16, 2008, 09:08:19 PM »
and how good is a zoom clutch
Offline ROSS
  • 1412
Re: clutch question
« Reply #2 on: October 16, 2008, 09:30:51 PM »
Re: clutch question
« Reply #3 on: October 17, 2008, 09:23:14 AM »
What ROSS said.  It's expensive compared to the others, but your not (as) likely to burn one out.
Offline HOGCAT
  • 20
Re: clutch question
« Reply #4 on: October 17, 2008, 11:03:07 AM »
  The Auto Zone clutch might be a cheap clutch, but if you tore it up in 2 runs your doing something wrong.  Or something wrong with the rest of running gear.  Like oil leaking into clutch, bad flywheel, adjustment wrong, riding pedal, geared too high, etc..etc,,....
Re: clutch question
« Reply #5 on: October 17, 2008, 03:09:08 PM »
it was $140 at auto zone. i have has the sammi for a tear no problems. Then went threw clutch and put this one in maybe the adjustment was wrong. I found the centerforce dual friction at summit but they cant get the pilot or throw out bearing or alignment tool.
Re: clutch question
« Reply #6 on: October 17, 2008, 03:37:38 PM »
Just give Hawk Suzuki or Low Range Off-Road a call.  They should be able to hook you up.
