timing belt
  • 11 Replies
  • 3426 Views
Offline madmark
  • 30
timing belt
« on: October 20, 2008, 03:44:40 AM »
Hi Guys
Tore into my sami that the timing belt broke on today.Well the belt isn't broke the bolt that holds the tensioner on is what broke,upon further inspection lower timing gear lose,uh oh lose crank bolt,the keyway looks like a swimming pool,gear is toast.will update with pic's of damage and repair in near future.
86 samurai,29x10.50x15 tsl ssx's,my-side2,44mm hd carb,DT header soon to have yj missing links,zor front bumper,rro rear bumper
91 tracker,30x11.50x15 tsl ssx's,tub front bumper
Offline idaholwb
  • 772
Re: timing belt
« Reply #1 on: October 20, 2008, 09:26:49 AM »
 Interesting that you had that problem on a Sami, I've only ever seen that on Trackicks before. Looks like you're in for a new crank and timing gear or possibly an excuse for a 1.6?  >:D
97 Sport
265/70-16s
2" lift
2.0 swap
Offline madmark
  • 30
Re: timing belt
« Reply #2 on: October 20, 2008, 09:52:36 AM »
No new crank this ran to good I will do the Jb weld and loctite 609 or 620 trick and see if works before I tear ity down.
Offline idaholwb
  • 772
Re: timing belt
« Reply #3 on: October 20, 2008, 10:16:12 AM »
 New crank. That keyway is way too bad to try to salvage.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline ack
  • 1659
  • Professional askhole
    • Ack's FAQ
Re: timing belt
« Reply #4 on: October 20, 2008, 02:46:19 PM »
x2 on what idaholwb sez.
It's been so long since I bought a re-man crankshaft (yep, same problem) that I can only guess here on a price.  Check your local auto parts store for an exact price.  You will need a core crankshaft to get the lowest price.
You might be able to find a salvage yard engine and have it reground and installed - or at least use it for a core because I don't think you damaged crank will be accepted as a core.
In case you were wondering what caused all this, take a look at my avatar.
For more info, try this thread:
http://bbs.zuwharrie.com/content/topic,89816.0.html
-Ack
Ack
Offline ROSS
  • 1412
Re: timing belt
« Reply #5 on: October 20, 2008, 07:10:20 PM »
I know several people that just used JB-WELD . I geuss the way to look at this is " what are you gonna do to the crank by doing it .  It is allready ruined. jb-weld is cheap. why not try it.
Offline madmark
  • 30
Re: timing belt
« Reply #6 on: October 20, 2008, 07:17:23 PM »
Hi Guys
Thanx for all the input.I went over to zuwharrie and did a search,There is a real good thread on this very subject.I went to advance auto today and got JB weld,and some locktite for retaining clyinder sleves.If it will hiold a clyinder sleve it will hold a timing gear!
« Last Edit: October 20, 2008, 07:19:09 PM by madmark »
Offline pepatt
  • 174
Re: timing belt
« Reply #7 on: October 20, 2008, 07:56:30 PM »
...If it will hiold a clyinder sleve it will hold a timing gear!
I don't know that I agree with that.  ???
A cylinder sleeve has a huge amount of surface area in comparison to the timing gear, and the forces are completely different. A cylinder sleeve is being pushed/pulled; the timing gear fights twisting/torque. Not even comparable forces.
Having said all that, what have you got to lose? If it doesn't work you still have a crank that's shot.  >:(
The issue to think about is: Where will I be when it fails? (and no offense, but I think it will.)
pepatt
Offline madmark
  • 30
Re: timing belt
« Reply #8 on: October 21, 2008, 02:36:33 PM »
thanx for the reply
I will be half through a window deep soupy as it gets mud hole,LOL!
Offline urbanwheeler
  • 696
Re: timing belt
« Reply #9 on: October 21, 2008, 09:02:12 PM »
It seems they all leak oil from the camshaft seal.
Offline madmark
  • 30
Re: timing belt
« Reply #10 on: October 23, 2008, 11:51:24 AM »
Hi Guys
Well I cleaned up the end of the crank and keyway,mixed up some slow setting JB Weld and put the key in the keyway,slopped on the JB.Installed new front seal,hope it doesn't leak,it kinda shaved the plastic coating off the bottom of seal as I put it in.
« Last Edit: October 23, 2008, 11:53:36 AM by madmark »
Re: timing belt
« Reply #11 on: October 23, 2008, 10:18:18 PM »
I have used a product called devcon on things like that, it has a lot of metal in it and you can machine it, not cheap but better than replacing a crank.
