samurai lift question
  • 1663 Views
« on: October 20, 2008, 01:26:53 PM »
I was going  to put the 3" calmini suspention lift on my samurai  but they are on back order till the end of the year,hellcreek has some springs that give 4 1/2 inch lift so my question is if I  go with the hellcreek 4  1/2 springs will a 2 1/2 inch drop pitman arm work for the steering? thanks Mike
Re: samurai lift question
« Reply #1 on: October 20, 2008, 01:43:01 PM »
It should, but at that point you might want to just look at switching to a High Steer setup from Sky Manufacturing.  You are running at pretty much the same hight as a Spring Over lift only with stiffer springs and receiving less axle wrap.  :)
Offline Amilla
  • 1076
« Reply #2 on: October 21, 2008, 11:23:21 PM »
Defiantly high steer!
Amilla
