V6 hard to start
  • 2649 Views
Offline gravity_powered
  • 43
V6 hard to start
« on: October 30, 2008, 10:46:41 PM »
I've been having an intermittent starting problem with my '98 2.5L V6 for a while now that seems to be slowly getting worse.
It takes quite a bit of cranking to get the engine going (for an injected motor anyway). Once it starts it coughs and farts and runs rough for five or ten seconds, then runs smoothly like nothing happened.
It happens both when hot and cold. The check engine light hasn't come on at all and I put a bottle of injector cleaner in the tank a while ago but with no improvement.
Any Ideas?
'98 2.5 V6 Grand Vitara
TJM Bullbar
Lightforce 170 driving lights
Wombat Racks roof rack
235/70/16 Toyo Open Country A/T
Offline blacknight
  • 987
    • Gonzookin
Re: V6 hard to start
« Reply #1 on: October 31, 2008, 05:44:36 AM »
Have you pulled the plugs to look at them? Sounds like a weak spark.
  • 43
« Reply #2 on: October 31, 2008, 08:07:30 PM »
Put new plugs in about 5000km ago. No difference.
TJM Bullbar
Offline IanL
  • 466
« Reply #3 on: November 01, 2008, 01:09:12 AM »
Try cleaning the connections of the coolant temperature sensor.
Offline 97TRAKIN
  • 600
  • Suzuki in Chevy clothing.
« Reply #4 on: November 01, 2008, 08:36:03 AM »
Make sure the fuel system is building the correct pressure and holding it. Sounds like your system is bleeding down when you shut the engine off. Causes could be fuel filter, fuel regulator, or fuel pump going bad.
Offline 97TRAKIN
  • 600
« Reply #5 on: November 02, 2008, 05:05:25 AM »
Or a leaky or sticky fuel injecter.
Offline eyb
  • 84
« Reply #6 on: September 08, 2009, 04:53:47 AM »
We have a couple of the same experiences here in the philippines. the culprit is the cam position sensor. per the suzuki parts catalogue, it comes as a set/assembly, but using the cam sensor from the esteem (that can be bought piece meal) works the same and comes out much cheaper.
