Kick lower arms
  • 12 Replies
  • 5352 Views
Offline Hawkeye Huey
  • 92
Kick lower arms
« on: October 31, 2008, 12:36:04 PM »
Anyone know what the center of bushing to center of bushing length of the kick rear lower arms is?
1990 GEO Tracker hardtop, 3" bod, 3.5"susp, rebuilt engine, Hawk SS torquer cam,Thorley tri-y 2 1/2" pipe, TT rockmonster T-case, Lockright F/R, 5:38 R/P, Pro-comp series 51 wheels 31" GY MTR's
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
Re: Kick lower arms
« Reply #1 on: November 04, 2008, 12:16:59 PM »
About 19"
   Kevin
  • 92
Re: Kick lower arms
« Reply #2 on: November 04, 2008, 01:03:45 PM »
Thank you I found a site that can make the lower arms with flex joint, just needed the length. They can also make the upper arm with flex joint. they call it a wishbone. Here is the link check it out. http://www.suicidedoors.com.
  • 92
Re: Kick lower arms
« Reply #3 on: November 04, 2008, 01:05:23 PM »
look in the 4-link parts section.
Re: Kick lower arms
« Reply #4 on: November 04, 2008, 01:16:07 PM »
a wish bone is for the rear end   and requires  the 2 lower trailing arms still be attached
commonly used on hydraulic cars for taller standing 3 wheel
in other words  if your talking about it on the rear end you will still need the lower trailing arms it cannot be put in place of these    and if your going to try and use it for an arm
well??????.....
Re: Kick lower arms
« Reply #5 on: November 04, 2008, 01:32:11 PM »
examples of a wishbone  suspension
Re: Kick lower arms
« Reply #6 on: November 04, 2008, 01:37:34 PM »
There not all that hard to make. I made some with joints from Ballistic Fabrication. www.flickr.com/photos/bentparts.
  • 92
Re: Kick lower arms
« Reply #7 on: November 04, 2008, 01:56:10 PM »
Bentparts, Yeah, it looks simple. Kicker is I don't have the skills/tools needed.  And not too many people offering to make them in here. Maybe this will change. I would rather have a fellow Zuker make my stuff. They at least have an intrest in the outcome.
Re: Kick lower arms
« Reply #8 on: November 04, 2008, 01:58:05 PM »
i dont understand your application
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
Re: Kick lower arms
« Reply #9 on: November 04, 2008, 02:48:37 PM »
I make them ;)
Re: Kick lower arms
« Reply #10 on: November 04, 2008, 05:56:57 PM »
I make them ;)
im capable of building them myself     i was just trying to understand his application
you should reinforce the center section   ive seen many break there  and IMO  offorad is going to be more abusive then some lay and play in a lowrider
  • 92
Re: Kick lower arms
« Reply #11 on: November 04, 2008, 08:36:07 PM »
My application is offroad crawler.
Offline MKOLSEN22
  • 217
  • Come on 32's
Re: Kick lower arms
« Reply #12 on: November 04, 2008, 09:08:11 PM »
Regarding the upper link of the rear suspension, the frame ends are not symetrical to the centerline of the vehicle. IIRC the driver's side is closer to the vehicle centerline to make room for the stock muffler. If you have some one like suicidedoors.com build it for you they will need detailed dimensions, etc.
Mike
